DD fiasco 5 w/pics
LSX RWD S/C conversion
But anyways, no this is a stock crank as this isn't the race engine.
Or I could just buy another pickup
The replacement is here.
Perhaps my luck is finally turning around. The repalcement engine arrived and it is in one piece. Then again when you see the picture of JBP's crate you will see that they weren't taking any chances on this engine in transit. There where 5 pallets used, one on the bottom and one on each side. On top of that the engine was wedged into place with dense styrofoam and finally strapped down.
I am off to start prepping the engine for install tomorrow morning. If all goes well my_bd and myself will be firing it up tomorrow evening.
im pretty sure a little duckt tape will fix that right up throw some more oil in and your good to go
i give you soo much credit for sticking with this iv been following your build since the begining and all i know is if i had the luck you had i woulda bought a honda a long time ago
good luck with #3
good luck with #3
#36
#37
It's Alive
At about midnight we fired up the replacement engine and she runs. We have a cam sensor code for which I will do a "case relearn" and there was a oil leak at the oil pressure sensor. After a few minutes the leak was tightened and we ran her again. We need to add some fuel at idle and down low. All in all it was a good feeling to hear her run.
The neighbors probably weren't happy with the noise and then when my_bd, Red2.4SS and RobHole drove away they were likely ready to go to sleep.
Myself I had to shower so I could have celebratory nookie.
I hear you.
That looks cool in a painful way.
Well I didn't start this because I wanted less power
good luck with #3
good luck with #3
#40
I'm old school
I'm sorry, but I have never been impressed with JBP. I would have fired them by now. I fired the first shop that worked on my car.
They pulled the powertrain out of my car. They tried to ship the trans via regular UPS, which you can't do because it's overweight. But the driver took it, and subsequently dropped it out of the back of the truck, literally. The shop failed to properly insure it, so we didn't get the full amount of the transmissions worth. I made the shop eat the difference on getting the replacement.
Then they put the engine back together and dropped a nut into the induction, which promptly got into #1 and jingled around like loose change, tearing up the piston. I can't tell you how many times they told me they where working on the car and caught them not.
That was 2 years ago. They are out of business now. Shocker.
TimJim
05-22-2012 01:55 PM
