DD fiasco 5 w/pics
Old 10-13-2008, 10:56 PM
KillerBee's Avatar
Damn that suxs might as well throw a 2.2 in here and call it a day
Old 10-14-2008, 10:31 AM
LSX RWD S/C conversion
victory_red_SS's Avatar
Originally Posted by theneelster
you're not using the jbp crankshaft are you? Maybe it's their cores that are fucked. Who knows.
That is funny because I am the one who arranged for the direct replacement crankshafts to be made in the first place by a company from the US.
But anyways, no this is a stock crank as this isn't the race engine.
Or I could just buy another pickup
Old 10-14-2008, 10:20 PM
The replacement is here.
Perhaps my luck is finally turning around. The repalcement engine arrived and it is in one piece. Then again when you see the picture of JBP's crate you will see that they weren't taking any chances on this engine in transit. There where 5 pallets used, one on the bottom and one on each side. On top of that the engine was wedged into place with dense styrofoam and finally strapped down.
I am off to start prepping the engine for install tomorrow morning. If all goes well my_bd and myself will be firing it up tomorrow evening.
Old 10-14-2008, 10:22 PM
XM15's Avatar
Hope everything finally settles down for you.
Old 10-15-2008, 11:44 AM
Iwhine's Avatar
Just JB weld It :P lol good luck with the rebuild
Old 10-15-2008, 11:54 AM
KillerBee's Avatar
NIce glad it came in one piece lol
Old 10-15-2008, 12:03 PM
Supercharged06's Avatar
im pretty sure a little duckt tape will fix that right up throw some more oil in and your good to go
i give you soo much credit for sticking with this iv been following your build since the begining and all i know is if i had the luck you had i woulda bought a honda a long time ago
good luck with #3
Old 10-15-2008, 12:18 PM
383_Stroker's Avatar
Originally Posted by victory_red_SS
I am thinking maybe just some JB Weld should make it good as new.
This is the last oil pan/block failure I had... meh.. was turning about 7600rpm when it fired to the wrong cylinder...
Old 10-15-2008, 06:01 PM
Iwhine's Avatar
Lol wtf did you do to that poor piston :P i think that might be your problem there :P
Old 10-15-2008, 06:05 PM
XM15's Avatar
Methinks that is what the "JB" in "JBP" is. rofl
Old 10-16-2008, 12:18 AM
  #36
Iwhine's Avatar
well if jb weld fails he's in trouble lol :P you know for the amount of motors you go through if your not worried about power a 2.2 would be cheaper :P lol
Old 10-17-2008, 02:25 PM
  #37
Cool It's Alive
At about midnight we fired up the replacement engine and she runs. We have a cam sensor code for which I will do a "case relearn" and there was a oil leak at the oil pressure sensor. After a few minutes the leak was tightened and we ran her again. We need to add some fuel at idle and down low. All in all it was a good feeling to hear her run.
The neighbors probably weren't happy with the noise and then when my_bd, Red2.4SS and RobHole drove away they were likely ready to go to sleep.
Myself I had to shower so I could have celebratory nookie.
good luck with #3
I hear you.
Originally Posted by 383_Stroker
This is the last oil pan/block failure I had... meh.. was turning about 7600rpm when it fired to the wrong cylinder......
That looks cool in a painful way.
Well I didn't start this because I wanted less power
Old 10-17-2008, 07:54 PM
  #38
2K5SS/SC?'s Avatar
Glad to hear things are finally looking up man! Get er' tuned and dialed in now after break-in.
Old 10-17-2008, 08:02 PM
  #39
We are going to do the tuning this weekend and once she has 500 miles the meth gets turned on and we dial her in.
That is if it lasts 500 miles.
Old 10-17-2008, 09:41 PM
  #40
I'm old school
Halfcent's Avatar
I'm sorry, but I have never been impressed with JBP. I would have fired them by now. I fired the first shop that worked on my car.
They pulled the powertrain out of my car. They tried to ship the trans via regular UPS, which you can't do because it's overweight. But the driver took it, and subsequently dropped it out of the back of the truck, literally. The shop failed to properly insure it, so we didn't get the full amount of the transmissions worth. I made the shop eat the difference on getting the replacement.
Then they put the engine back together and dropped a nut into the induction, which promptly got into #1 and jingled around like loose change, tearing up the piston. I can't tell you how many times they told me they where working on the car and caught them not.
That was 2 years ago. They are out of business now. Shocker.
Chantie88
Recalls
06-12-2014 02:12 PM
Gmoney06
02-15-2014 09:58 PM
Trent1080
07-10-2013 11:49 PM
TimJim
05-22-2012 01:55 PM
inmymemory
12-21-2009 09:32 PM
Quick Reply: DD fiasco 5 w/pics
