View Poll Results: Did you use lock tight on your pully bolts or what did you use?
Yes what brand name
14
20.29%
NO did not use anything
55
79.71%
I used something else please explain
0%
Voters: 69. You may not vote on this poll
Did you use a lock tight product on your pully? Poll
Ok guys just wanted to know who has used lock tighton the bolts or who did not or you used something different poll is above please specify eactly what you used please so those who have not used it can get buy it thanks
ok thanks casue i did not see any when i took off my blue bolts to install my 2.9 pully its 15lbs of tq to be exact that is what is on the stage 2 kit paper anyways
the blue loctite is the loctite that you can remove the bolt from without to much of a struggle the red loctite is more of a permanant thing so dont use red go blue...o and make sure you just put a drop on otherwise you might have a problem getting the bolts out
see that is the thing i dont like is that it will be harder to take out the bolts in the long run but they did not put any on the blue bolts with my stage 2 kit and tha is what i used to tighten the pully down so i think i am good just gotta keep an eye on there everyonce in a while
I used red lock-tite on my billet-flow 2.7. I didn't need to, just to be cautious. It wasn't too bad removing the bolts but I can't get the stuff out of the theads. I've switched to another hub since then.
if you tighten the bolts good and check the every once in a while you should be fine...when i put on a 2.9 pulley tho i think im gonna just put a dab of blue on to be safe o and if you just put a drop on of blue your safe they will not come out on there own but it wont be like bolt death getting them out just a bit tougher...congrats on the 2.9 pulley man im jealous cant wait to get mine
haha your probably right but i just always like to be extra safe...just dont want something rediculous to happen and leave me with a f'ed up car and way more $ than i have to fix it
so on the other hand 07cobaltss how do you like the 2.9 pulley make a noticable diffrence? im looking to get one very soon
haha yea i hear the flaming coming haha but i do agree and most people will that it is the safest smaller pulley to run on the stage 2 kit other than going bigger which defeats the purpose of the stage 2 haha but im happy you like it man i cant wait to order mine...going with polished for sure they look so good, and im happy to hear you can feel a diffrence power wise due to it its awesome for only $50-55 now with the stage 2 hub can do alot
EDIT:nates 2.9 is my next purchase because i dont want to put 60lb injector on have something happen and void my warranty with a pulley you can get away with it easily because you can change back to the stock pulley in 15 minutes if need be
I've seen more than a few come out.
search....
holy batman a old thread hahahahha i also used a black marker to mark the bolts so i can see if they moved but i have not used loc tight or anything and they have not broke loose yet
theres TONS of different red loctites
