Disabling O2 sensor/Spark anti fouler trick explained?
Old 04-01-2008, 04:53 PM
Immortal Technique's Avatar
I'm not sure if i'm explaining it clearly. I just bought the ZZP catless DP without an O2 bung and so there isn't a spot for the sensor.
Old 04-01-2008, 04:59 PM
07cobaltss's Avatar
ahhhhh, haha yeah take it to an exhaust shop and have one welded in for like 20 bucks. or try and find a simulator
Pickles's Avatar
Originally Posted by 07cobaltss
drill holes? lol no you dont have to
just as simple as pulling the rear 02 out, putting the peice i send you on it, than screwing it back in. do drilling, only tool needed would be an openended wrench
Can this anti-foul thing be done on a front o2? I guess I am also not understanding what the effect of putting these spacers on the 02 sensor...
Old 04-01-2008, 05:05 PM
Zach06CobaltSC's Avatar
basically what its for is if your getting a CEL because you deleted your cat. I don't have any emission testing / smog testing so I took out my cat and have a 3inch exhaust system. Now I have a check engine light because of no cat.
So I am going to buy this 7 dollar piece from this guy, unscrew my o2 sensor, slip this on the top of it, and screw it back in. There is no drilling required unless you do not have an o2 bung.
Let me know when your ready to sell one.
Old 04-01-2008, 10:15 PM
Old 04-16-2008, 04:58 PM
black 06 balt's Avatar
Old 04-16-2008, 06:13 PM
07cobaltss's Avatar
sorry for the no reply. as for this anti fouler working on the pre 02. i really dout it, is there a reason why you want to disable this? anyone interested in purchasing one, please PM me.
Old 12-10-2008, 01:43 PM
07candysedan's Avatar
the defouler trick didnt work in my car does anyone know where to get a simulator?
Old 12-10-2008, 02:07 PM
Fail Less.
Bika's Avatar
simulators do not work on our cars. ecu will throw a code for HO2S insufficient activity.
as for the non-fouler on the primary o2 sensor, don't do that. that will make your fuel trims FUBAR.
Old 12-10-2008, 02:10 PM
ShortStack's Avatar
yea you dont need to mess with the one on the exhaust mani, just the one on the DP.
Old 12-10-2008, 03:03 PM
  #36
rnjmur's Avatar
Yeah, that is what I was going to say. The PCM uses the first O2 sensor to make fuel trim adjustments. If you start messing with it you can cause all kinds of problems.
Old 12-10-2008, 04:18 PM
  #37
light'bolt's Avatar
yep your gonna need to disable that code from the PCU if your not willing to get an O2 bung placed on your DP. HPT will do it, not sure what other program can do it though I'm sure there are others out there.
I'm surprised who ever tuned Zach06CobaltSC didn't disable that code when it was tuned. I wonder if they locked your PCU too. I know HPT is capable of doing that.
toysareforboys
11-17-2015 05:22 AM
dennis69
10-20-2015 07:39 AM
metroplex
09-27-2015 07:48 AM
Sean Cummings
09-11-2015 09:35 PM
Quick Reply: Disabling O2 sensor/Spark anti fouler trick explained?
