do we have a front diff?
do we have an open diff, and would it be a bad idea to go turbo if i dont have the lsd??
im planning on buying the hahn turbo by the end of the summer i know ill spin a **** load more with no lsd but would it still be ok to turbo?
i just wanted to see how much more slipping i would get from the turbo if i dont have a lsd.
i got a TD wont help much but stops from wheel hop, i just still wonder if ill be ok with not having a lsd and going turbo
I you pick up your trunk floor to access the spare, look on the left corner and there will be a sticker with a bunch of numbers in alpah and nuerical order. These are your regular production options (RPO)codes. If you see G85 listed, you have a limited slip diff.
Just post up your VIN and I will check it through GM to tell you if you have one or not. Some other people on here might be able to do it also. Us GM techs have access to that information, we are able to look up the build of the vehicle with the VIN number
