driving the ss/sc cold
Old 10-31-2010, 11:00 PM
ecot3c inside's Avatar
anyone just start there car and drive? Not giving it a chance to warm up. I ask because I normally wait at least 3 mins for my car to warm up, but just a little bit ago I had to move my car really quick, and going into first gear it usually shakes violently when I have to do quick moves like that.
Also looking at my wideband the afr goes to 10.0 then after maybe 20 seconds moves it's way up slowly to stoich, I think this just may be a warm up for the car?
anyone else have this issue?
Old 10-31-2010, 11:04 PM
devon9832's Avatar
I usually let the rpm's rest around 1k before I take off... takes about 15-20 secs... Then i'm off.. Other than that, when I drive without letting it warm up, it seems to ride a little rougher for the first mile or so then it's fine.
Modern cars don't need to warm up as long as older cars did. We can take off and let the car warm up as we go along.. Jus hopefully you don't get on it immediately after you start it up...
Old 10-31-2010, 11:06 PM
I'm on e85 as well so not sure if that makes a difference.
Old 10-31-2010, 11:09 PM
D_sean257's Avatar
yeah, Rides a little rough for a second, usually just in 1st and 2nd for me. I normally let it warm up though
Old 10-31-2010, 11:10 PM
b00sted06ss's Avatar
whenever i start it on a cold day and the coolant temp is below and 100 and i start driving all the shifts are rough and not smooth till the coolant temp is above 100 weird..
Old 10-31-2010, 11:13 PM
Maupin SS/SC's Avatar
me too i let it settle a bit and it is jerky through the neighborhood then its fine
this is basically how mine is! I usually let out the clutch slower when this happens. I'm just wondering if the ss/sc runs rich normally for the first minute on startup.
Old 10-31-2010, 11:16 PM
D_sean257's Avatar
yeah mine is always jerky too at first. Sometimes I will be in 2nd and even 3rd gear at about 3500rpm and give it gas and the car will bounce a few times then smooth out. Does that happen to any of you?
Old 10-31-2010, 11:19 PM
yep! just had to pull it in the drive way and it was jerking erratically, might be my fault for putting it in gear in so low of rpms when warming up. But yah it sometimes jerks going into first, second and sometimes 3rd.
my gf always yells at me, then I yell at her telling her to stfu because it's not me.
Old 10-31-2010, 11:22 PM
D_sean257's Avatar
yeah, sometimes my friends just look at me and im like.. It seriously isnt my fault lol. I cleaned my throttle body earlier in the summer and seemed to help alot. Maybe It is time for another cleaning..? It also fixed the idle bounce I was having when id come to a stop.
Old 10-31-2010, 11:26 PM
cleaning the tb fixed your idle bounce? like the afr bouncing? that's odd.
Old 10-31-2010, 11:28 PM
Joe Schulte's Avatar
I normally let the coolant get to 75', dunno why, just one of those things.
Old 10-31-2010, 11:30 PM
thedude411's Avatar
i think my car drives better when its cold... shifts are crisp, steering feels nice and tight... when its hot my car drives like a POS
D_sean257's Avatar
yep, When I would stop at a redlight my car would bounce and almost stall especially when the ac was on... there is a thread about it on here ill find it.. but yeah cleaned it and completely fixed the bounce. But yeah the car still runs like ass when I dont let it warm up lol
Old 10-31-2010, 11:32 PM
D_sean257's Avatar
https://www.cobaltss.net/forums/2-0l...inally-116051/
Old 10-31-2010, 11:45 PM
Nighthawk243's Avatar
Since I'm usually out the door right when I need to leave, I rarely do. The only exception is winter while I'm de-icing the windows.
The only thing I notice when the Cobalt is cold is that the clutch likes to slip for about 2 seconds if I'm not getting on the throttle heavy for that initial first to second shift. If I apply a moderate amount of throttle and shift at 3K, then it won't do it.
Old 11-01-2010, 12:06 AM
Karlen89's Avatar
I start my car and wait a min of a couple mins before I move it. Occasionally it likes to buck once it goes into 2nd, and slight increase in throttle makes it worse...so I get pissed off and clutch back in and rev it out to like 4k and slowly release the clutch again.
Old 11-01-2010, 12:50 AM
CanadianCobalt's Avatar
My car cold also is bucky and the shifting almost fels notchy.
Once it warms up it smooths out to perfect though. Takes a k or 2.
I try to warm it up if I can, mostly becase it's getting cold here .
Joel
Old 11-01-2010, 12:58 AM
Joel
ya the shifter is a little rougher as well.
still trying to find out if it's normal peg 10 on the wb and gradually raises to stoich for about 1 min.
Old 11-01-2010, 12:27 PM
xxxxsh4d0wxxxx's Avatar
Hop in that bitch and hammer it!!!
I never drive it when coolant temp is below 100°F, usually I'll let it warm up completely. I smoke, I don't smoke in my car, though, so having a cigarette before I start driving kills about 5 minutes.
Cars with a lot of miles/older cars, should be given time to warm up before driven, especially in the winter. You guys who just get in and go, I'm not sure how many miles you have, but I'm at 66,xxx and I'd rather let it warm up for 5 minutes then stress a cold motor by putting load on it.
Old 11-01-2010, 12:41 PM
InfraRedline's Avatar
I always let mine warm up a few mins before I go.
And yes its normal to go rich for a while after startup. Its the car being in open loop until it is ran for a while
Old 11-01-2010, 02:04 PM
Red05SS/SC's Avatar
I let my car warm up to about 90-100 degress before leaving to go anywhere.
Old 11-01-2010, 02:08 PM
hahaha, you don't smoke in your car! LMAO, I do!.. it is so easy to get rid of the smell and possible stains.
thanks, your the bomb!
Last edited by ecot3c inside; 11-01-2010 at 02:08 PM. Reason: Automerged Doublepost
Old 11-01-2010, 02:11 PM
Turbalt2010's Avatar
everyday my car runs for about 10 minutes before i drive it. the temp is about 150 ish. today it was 147 haha
Old 11-01-2010, 09:05 PM
a_joyner's Avatar
I think it's just the way these cars are tuned. My car does that also....if you stomp on it when it's still cold it will fall on its face. Once the car goes into closed loop it's fine.
Quick Reply: driving the ss/sc cold
