Dual Pass Question
East Coast Cobalts
Dual Pass Question
My next mod is going to be the dual pass endplate and so my question is what kind of temp drops did everyone see before and after the dual pass?
Then something IS not right. You have the same setup and tune (basically) as me...
I was 100-110* IAT2
Are you sure you are spraying.... did you put the hose out the hood and watch it spray out when you get into boost?
I was 100-110* IAT2
Last edited by 1badBlueberrySC; 08-21-2009 at 09:28 PM. Reason: Automerged Doublepost
check that pump... and cooling will always help... might not get u hp but it will keep the hp u start out with b4 it heat soaks longer.... i heard its a 2 day job to do it... i am thinkin about doing it when i get my blower ported.
Then your mixture isn't right....
Get 1 gallon of distilled water and 5 bottles of HEET.
Mix the 5 bottles of HEET in a CLEAN empty 1 gallon jug, the rest with the distilled water!
normal driving.... you may want to check your H/E pump then.... because out of boost the meth wouldn't spray anyway!
Empty your H/E and fill it with 70% distilled water and 30% Dexcool coolant and some Water Wetter
East Coast Cobalts
Yea the heat exchanger has that mixture in it. The pump has to be working from what i can see cause it will drop a lil when i get on it a lil which kicks the pump on.
Something isn't right dude.... your meth doesn't spray untill 6psi so under no or very low boost situations you are only on the H/E...
You shouldn't be that high without something being up...
East Coast Cobalts
Thats what i was thinking but i am pretty sure the h/e pump is working because it bleed itself out when i recently switched it to distilled/dexcool
