Dyno Results.
Old 10-19-2008, 05:34 AM
  #126
Zach06CobaltSC's Avatar
my peak hp pulls all the way through, if I rev to 7k, my peak is generally right at 7k or very near to it. I am not sure on my torque. I am trying to get a level hp and torque across the board. I will post dyno's and graphs and all that good stuff up on tuesday after I do my runs.
Old 10-19-2008, 12:17 PM
  #127
Tennpenn83's Avatar
remember the formula for horsepower tho..
hp = (tq x rpm)/5252
you are always going to have more torque than horsepower before 5252 rpms, and more hp than tq after 5252. best bet is to tune specifically for a flat torque curve, and not worry so much about peak horsepower
Old 10-21-2008, 11:44 AM
  #128
Yup, I am going for the smoothest torque curve I possibly can. Today is the day. The dyno time is from 2-2:30 central give or take. 30mins for 50 bucks, not to bad, and I should be able to get like at least 8-10 runs in.
I can't wait to see what the nitrous can do. I don't know if I am going to spray the 55shot or not. But for sure am spraying the 35shot.
How much timing do you guys feel is safe with a 35shot and methanol. I am using just straight windshield wiper fluid. Possibly some HEET added in for the extra security. Let me know thanks.
Old 10-21-2008, 12:02 PM
  #129
recklessactn's Avatar
so u got ur numbers on a dynojet or.......
Old 10-21-2008, 01:31 PM
  #130
yea there sae corrected numbers from a dynojet. Same thing I will be running on today.
Old 10-21-2008, 02:53 PM
  #131
post those numbers again bc i have higher number than u and i ran on a mustang dyno...
Old 10-21-2008, 05:29 PM
  #132
hungryhip-ccp's Avatar
so whats the deal ZACH??? its after 2:30.............................................. ...........did it blow or what? j/k
Old 10-21-2008, 07:18 PM
  #133
Tennpenn83's Avatar
bump for updates...
Old 10-22-2008, 05:34 AM
  #134
kevsmu4's Avatar
interesting..... I plan on running the exact same setup as zach except different exhaust.......
Old 10-22-2008, 07:21 AM
  #135
Well I had the jets in for a 50 shot and I wanted to start with a 35shot first. I leaned some stuff with hptuners while i was there and spent an hour on the dyno, was only charged 50 bucks. I enjoyed messing around with my torque curve, getting 250 torque to the wheels isn't bad, and neither is the 280whp.
However I am ignoring the dyno sheets and everything as this was for tuning only. I still have some things to tweak out but to be honest, I really didn't gain anything besides more torque, and a much smoother torque curve.
To be honest I don't want to post the dyno sheets because I went from 18 inch stock perelli's to 16inch ridiculous tires. I think that there is a good possibility that the dyno could have been off due to this.
So basically all I am offering up to you guys, is that I have a really smooth torque curve, peak of about 250ish, and almost 280whp.
Another interesting fact is that no matter how hard I tried, I could not hit anything higher then 140's in the iat2's which pleased me. The methanol is doing its job well.
Tuesday I am going back to the dyno shop to test out the 35shot. I didn't want to start with a 50 shot, because I like to always be on the side of caution.
ALSO as another update I believe my fuel pump is dieing. What would the signs be of a fuel pump dieing? I was driving, and the pump stopped functioning. I tried to start the car and the pump would not prime at all. I am 99.99% sure its the fuel pump, just wanted to make sure the symptoms sounded right.
I am sorry to disappoint you guys, I wanted to run the 50 shot, but I like to be safe.
Last edited by Zach06CobaltSC; 10-22-2008 at 07:21 AM. Reason: Automerged Doublepost
Old 10-22-2008, 09:27 AM
  #136
ShortStack's Avatar
Whack.
Old 10-22-2008, 10:22 AM
  #137
ralliartist's Avatar
so did you actually spray? What size tires are you using? 280whp and 250wtq sounds stupid for a 50 shot. Go blow your car up. LOL.
Old 10-22-2008, 10:31 AM
  #138
ebristol's Avatar
Who cares what the numbers say. Every dyno is different.
Here is my dyno run on the OTT Stage 1. I have an intake, GMPP manifold, ZZP dp, Magna Flow catback and CX Racing Dual Pass HE.
I have seen other dyno charts from other people with simular setups claim + 270whp.
BFD IMHO!
I could have drove an extra 30 minutes to a happy dyno to inflate my numbers if I wanted to...
Old 10-22-2008, 10:35 AM
  #139
invisible's Avatar
^^^^^Agreed. His first dyno #'s are super inflated.
Old 10-22-2008, 11:26 AM
  #140
lsjwannabe's Avatar
Your idc's would be through the roof if your pump was going also you would notice a significant dip in your dyno graph were it was running to lean and loosing power.
Old 10-23-2008, 04:46 AM
  #141
Thanks for that information lsj.
I did not spray at all. I don't plan on spraying until I get my fuel pump issue figured out.
Sean - I believe my fuel pump isn't slowly like going out, its basically cutting on and off. Do you have any idea what would do that? I'm assuming there is a fuse for the fuel pump, I am going to make sure there is nothing tapped into that.
I will let you guys know the out come of things.
brickloaf
Show & Shine
56
06-18-2019 12:51 PM
01-12-2016 12:01 AM
maliki778
10-01-2015 07:39 PM
09-27-2015 08:53 PM
breds2k
19
09-21-2015 10:24 AM
Quick Reply: Dyno Results.
