Dyno: STG2
Dyno: STG2
Stage 2, GMPP Catback, GMPP Manifold, Injen CAI, TTR Engine Mount, Exedy Clutch + Flywheel
Consider a 350z, 280bhp (non stock) model put down 227hp on the dyno, a SL 500 (exhaust) rated 309bhp put down only 240hp, and audi TT (non stock) put down 159hp that day
GM Stage 3 pulley and dual pass intercooler end plate on the way.
I say it's the dyno. Look at what the other cars put down comparatively. I would keep that dyno sheet so when you beat some ricer you can show him that you only dynoed 220hp.
Last time I dynoed 228hp before GMPP Manifold and Injen CAI, they couldn't give me AFR, so I went to a different one. This is the one I'll be using from now on. Its ok compared to what other cars where putting down.
i agree . the other cars looked low too , so your numbers were not bad
What downpipe should I choose, if at all, based on the current setup with the addition of the stage 3 pulley and dual pass which are in the mail atm. I'm need one with a CAT. Should I choose 3" or 2.5". Would 3" be a bit much since the rest of the piping is 2.25"?
Me and my brother were looking at our downpipes and came to that same conclusion. They are decent in diameter. The only thing I plan on doing is ditching the cat. In fact the stock exhaust doesn't look that bad either except right before it gets to the fake rear. Then it necks down pretty small.
i still have this catless dp from that car sitting in my garage. no one wants them. the stock cat flows enough, and the actual piping is good.
It doesn't matter to me if I see 1 horsepower from removing my cat. It's free and gets removed on every car I have I don't ever look at exhaust, intakes etc as power mods. Sure you can get some horsepower from them. I look at doing those mods as supporting mods for big additions like cams, heads, power adders etc, as it will be a restriction when you get into bigger mods. That's the way I always build my cars. So my conclusion is to save a buck on this and just ditch the cat, keep the dp, and maybe just replace the restrictions in the cat back.
celicacobalt
07-16-2008 01:12 AM
