dynoed the car a little pissed
#51
I put down 357 with tvs and 1.26g/cyl
I don't think you are gonna find your missing hp in your maf!
After checking your log file i would work on your timing table and wrap it out to 7500, the tvs will keep making power if tuned right.
Too bad you didn't have a lil more fueling left.
Last edited by elite_Cyborg; 06-21-2010 at 03:20 AM. Reason: Automerged Doublepost
#52
My timing table
What it should look like.
#53
you are correct. Check it out this is a comparison of my cylinder air mass and the cylinder air mass that it should look more like.
My timing table http://i12.photobucket.com/albums/a2...nShot002-1.jpg
http://i12.photobucket.com/albums/a2...nShot001-1.jpg
But forcerius, fix your fueling already.
#58
Rent me! per hour
g/cyl means dick. as long as your car runs what afr you want with the maf and pe combined. **** it. it will not effect power.
i run around 1.04 g/cyl on a 2.6 ring with the tvs. maf thinks it's moving only 24lb/min still cranks out 375 whp daily. the sooner you concentrate on power, and give up perfection, the happier you will be.
#59
more to tuning than AFR and timing.
Not bad numbers though. However, I got that on the 3.1 pulley....
11.2 AFR, 20* of timing and a hot/humid day.
My torque wasn't that though. Hit 256 on the highest run for the tq.
#61
#63
Area maybe you can point me in the right direction I posted my tune. What do you think I can do to it to get more hp besides changing the stoich cause I already changed that in my new tune. Also what a/f is everyone running on e85.
#64
Im running 12.0 until 4500rpms then 11.7 until redline. When you change stoich to 9.7 hopefully you dont have idle issues like I did. My idle would get high, around 1100 rpms then would go really lean and want to die. I am going to try messing with my idle overspeed timing to see if I can get it under control
#65
Yeah right now my idle is fine and doesn't go lean it sits right at 14.7 for the most part. I am not going to tune my car with my wideband reading 14.7 though. I am going to program my lc1 to read for e85 I am praying when I do that and get my rsfs I can pull at least 345hp.I need to check my sc and map and make sure its sitting right since the dual pass install.
#67
#71
Hey quick question. I installed dual pass option b with a new intake mani gasket. Could I be loosing boost from the sc or manifold not bolted down all the way? I am seeing 20 psi with a 2.8 pulley and 3in exhaust. I am just trying to narrow down the problems and why I only made 305.
#72
