dynoed the car a little pissed
Old 06-21-2010, 03:16 AM
  #51
elite_Cyborg's Avatar
I put down 357 with tvs and 1.26g/cyl
I don't think you are gonna find your missing hp in your maf!
After checking your log file i would work on your timing table and wrap it out to 7500, the tvs will keep making power if tuned right.
Too bad you didn't have a lil more fueling left.
Last edited by elite_Cyborg; 06-21-2010 at 03:20 AM. Reason: Automerged Doublepost
Old 06-21-2010, 12:38 PM
  #52
roderick's Avatar
Originally Posted by Dainslaif
The guys on the HPTuner forums said cylinder airmass calculations were done off the MAF tables and it'd be wonky if they were raped instead of being properly tuned. That's probably why.
you are correct. Check it out this is a comparison of my cylinder air mass and the cylinder air mass that it should look more like.
My timing table
What it should look like.
Old 06-21-2010, 02:18 PM
  #53
Dainslaif's Avatar
My timing table http://i12.photobucket.com/albums/a2...nShot002-1.jpg
http://i12.photobucket.com/albums/a2...nShot001-1.jpg
I'm not sure it's supposed to creep up like that. Mine flatlines at about 3500, like yours does, but it stays at 1.20, +/- 1 cell.
But forcerius, fix your fueling already.
Old 06-21-2010, 02:48 PM
  #54
csementuh's Avatar
click
Old 06-21-2010, 03:12 PM
  #55
South Central *********
JapEatr's Avatar
Ditto
Old 06-21-2010, 03:25 PM
  #56
INFE's Avatar
Go turbo it's more fun I wish I was running e85 it would be fun too see how much power I would pick up. I'm too scared to run more then 16* on pump gas with the stock motor
Old 06-21-2010, 08:49 PM
  #57
bamaboy22's Avatar
ive had no problems so far
Old 06-22-2010, 12:44 AM
  #58
Rent me! per hour
Area47's Avatar
g/cyl means dick. as long as your car runs what afr you want with the maf and pe combined. **** it. it will not effect power.
i run around 1.04 g/cyl on a 2.6 ring with the tvs. maf thinks it's moving only 24lb/min still cranks out 375 whp daily. the sooner you concentrate on power, and give up perfection, the happier you will be.
Old 06-22-2010, 12:46 AM
  #59
G85 SS's Avatar
more to tuning than AFR and timing.
Not bad numbers though. However, I got that on the 3.1 pulley....
11.2 AFR, 20* of timing and a hot/humid day.
My torque wasn't that though. Hit 256 on the highest run for the tq.
Old 06-22-2010, 12:50 AM
  #60
Rent me! per hour
Area47's Avatar
i hit 258trq on mine with my **** ass winter tune with a 2.9. goes to show how much i don't care about my winter tune. lol
Old 06-22-2010, 07:50 AM
  #61
roderick's Avatar
gochta area. Like I said before I am switching my stoich all the way over to 9.7 and see what I cant get to happen.
Old 06-22-2010, 10:00 AM
  #62
freakta's Avatar
sub for later
Old 06-22-2010, 10:13 AM
  #63
roderick's Avatar
Area maybe you can point me in the right direction I posted my tune. What do you think I can do to it to get more hp besides changing the stoich cause I already changed that in my new tune. Also what a/f is everyone running on e85.
Old 06-22-2010, 12:26 PM
  #64
InfraRedline's Avatar
Im running 12.0 until 4500rpms then 11.7 until redline. When you change stoich to 9.7 hopefully you dont have idle issues like I did. My idle would get high, around 1100 rpms then would go really lean and want to die. I am going to try messing with my idle overspeed timing to see if I can get it under control
Old 06-22-2010, 02:05 PM
  #65
roderick's Avatar
Yeah right now my idle is fine and doesn't go lean it sits right at 14.7 for the most part. I am not going to tune my car with my wideband reading 14.7 though. I am going to program my lc1 to read for e85 I am praying when I do that and get my rsfs I can pull at least 345hp.I need to check my sc and map and make sure its sitting right since the dual pass install.
Old 06-22-2010, 04:30 PM
  #66
Rent me! per hour
Area47's Avatar
stoich afr, or wot afr?
stoich on mine is 10.4
wot afr is 11.3. i think
Old 06-22-2010, 11:29 PM
  #67
roderick's Avatar
yeah i was wondering about wot. I should set mine around there cause e85 takes more to generate power.
Old 06-22-2010, 11:31 PM
  #68
RooTBeeR's Avatar
u already run out of fuel with ur leaner afr dont u?
Old 06-23-2010, 09:51 AM
  #69
roderick's Avatar
sure do thats why I am getting ottps new rsfs
Old 06-24-2010, 12:33 AM
  #70
roderick's Avatar
I just redid my timing table take a look any pointers are more then welcome.
Old 06-26-2010, 01:24 PM
  #71
roderick's Avatar
Hey quick question. I installed dual pass option b with a new intake mani gasket. Could I be loosing boost from the sc or manifold not bolted down all the way? I am seeing 20 psi with a 2.8 pulley and 3in exhaust. I am just trying to narrow down the problems and why I only made 305.
Old 06-26-2010, 01:25 PM
  #72
RooTBeeR's Avatar
is that 20psi on the stock boost gauge?
Old 06-26-2010, 04:40 PM
  #73
roderick's Avatar
nope I got a redline so its a after market boost gauge.
Bluelightning
11-11-2015 02:41 PM
chefhhr
10-26-2015 10:36 PM
hawkssoccer11
09-30-2015 12:14 PM
medic710
09-06-2015 08:53 PM
Quick Reply: dynoed the car a little pissed
