Dynoed the Harrop again today
Old 10-04-2008, 11:46 PM
Rodimus_Prime's Avatar
Well since the GM bash in OH the weather was about 30 degrees colder, I had somewhat of a better tune, and also running the meth injection for the first time so that kinda threw things off a bit
I'm still running the 75mm pulley, only getting 91% duty cycle, about 20.6PSI
The dyno was on a dynapack dyno thats the kind that your wheel hubs bolt to, no rollers
Laid down 282.7hp and 254.8 tq, keep in mind this is on stock timing and at 11.3AFR, so theres some room for improvement
I'm strongly considering moving to the 80mm as many have stated to do so for a car thats running a stock motor.
Some good things, NOT one touch of knock at all in the entire run and IAT2 never exceeded 135, weather was in the 60s today with light rain
Old 10-04-2008, 11:52 PM
slowswap's Avatar
Play with the timing already!!!!!!!!!
Congrats dude. I've been waiting to see some decent numbers. Got any videos of it at all?
Old 10-04-2008, 11:54 PM
hungryhip-ccp's Avatar
hmmm i would of expected alot more... but im sure your just getting into it as your tune sounds a little "rough around the edges"
when you say stock timing do you mean stock stage 2 timing or STOCK timing... i assume your running a stage 2 tune with only the injector table modified for 60's? ohh and anything over 80% idc is not good...
Last edited by hungryhip-ccp; 10-05-2008 at 12:17 AM. Reason: Automerged Doublepost
Old 10-05-2008, 12:16 AM
ralliartist's Avatar
What's up with the low numbers from the tvs cars? Go hit the track up, I'm more curious about trap speeds than I am your dyno numbers.
Old 10-05-2008, 12:18 AM
ehh its all in the tune... i mean you can squeeze another 40hp out of that set-up with a aggressve tune
Old 10-05-2008, 12:21 AM
slowswap's Avatar
Yeah, from how he described it, I'd say you're right.
Old 10-05-2008, 12:24 AM
I'm still wanting to know his trap speeds at the track. Dyno numbers don't really mean much of anything to me, unless he has some before and after numbers.
Old 10-05-2008, 12:25 AM
shoot for a 11.9 richening to a 11.7 after 6000rpm and it will ease up on the injectors a tad! 11.3 is way conservative
Old 10-05-2008, 12:39 AM
R&C_rallySS's Avatar
Congrats Matt!!
I see 300hp in your future...
Old 10-05-2008, 01:52 AM
Plastic's Avatar
282.7hp seems kind of disheartning, almost makes me want to give up on a future tvs and just put the car on the bottle after the motor is built.
But then again dyno #'s are pointless, every dyno is different. But like ralliartist practically said, track times are what matters
Old 10-05-2008, 01:57 AM
well, I dunno how good of a driver he is. Considering that no one has went 12's with the tvs, it doesn't look promising. I'm just curious about the trap speed. If he traps well over 110mph, then I would be happy if I was him.
With a trap speed that high, he SHOULD run 12's easily though, but once again, why hasn't anyone else?
JimzSS's Avatar
I ran 104.5mph in my ss/sc...any hp guesses? I am getting dynoed and tuned the 25th. Sorry for the thread jack. Those are promising #s.
Old 10-05-2008, 09:32 AM
Tennpenn83's Avatar
thought there was a tvs somewhere that went only 13.9 but @ 110. easy to say no traction... but 110mph trap speed should be good for high 12's
Old 10-05-2008, 01:45 PM
Blown 4-banger's Avatar
This is exactly why I'm not doing the TVS. There have been many M62 cars running like 18 psi, that have made more than 282 whp.
Old 10-05-2008, 01:48 PM
slowswap's Avatar
But there's a difference, he can swap pulleys, make a more aggressive tune and surpass what the M62 will do. And the M62's making those numbers are far more modded then what this guy has I'm sure.
Old 10-05-2008, 03:02 PM
The tune is far from aggressive I know theres alot to be picked up in it. Ive added alot of new things so its going to take some time to set up.
I'm sure theres M62 cars running 282whp but I can almost promise you none of them are doing it under 134 IAT2 at 7000rpm
i have a fujita intake, 60s and zzp header, downpipe and exhaust all 3 inch and leaking
im sure with a head and cams id pick up a bunch too and run the 75mm more effectively
Sorry to disappoint but the track isnt happening until i get rid of this 9100 credit card debt because i need axles clutch and drag radials thats not happening anytime soon. Maybe in a year or two
Old 10-05-2008, 05:11 PM
Moderator Alumni
zinner's Avatar
When I did my dyno test with the M62 with a 2.8 I only got about 10 extra hp when I bumped up the timing. You might be able to get it over 300hp.
Old 10-05-2008, 05:23 PM
im optimistic i can do it (more timing) even with the 75mm on, im not sure what the big reason is why ppl feel they can make better power with the 80mm on
Old 10-05-2008, 05:42 PM
Deathscythe's Avatar
I don't remember reading anything about your cooling mods in the past, but I'm sure you've heard all about that by now. I'm getting almost everything possible for cooling, so I can benefit from more timing in the long run. I have the 80mm on mine, so you might be dealing with the chokepoint on the intake side of the head because of the added airflow.
Old 10-05-2008, 07:51 PM
Timmay's Avatar
if he or anyone else traps 110 mph and gets a 13 second pass, that just means they had a crappy launch. wheel spin, hop, etc
Old 10-05-2008, 07:55 PM
Steven Flit's Avatar
Who cares about DR, and axles. Roll out of it, and see how you trap. I drop the clutch at 5k, but then again I have full motor mounts.
Old 10-05-2008, 08:29 PM
Problem with doing that is as soon as I shift into 2nd at 7000rpm I spin the **** out of 2nd, if you let off the throttle then your wasting your time even being there.
A 13.9 at 110mph with gross 60fts would mean absolutely nothing to me
Old 10-05-2008, 08:36 PM
It would mean that you suck at driving to me. LOL. I've seen as gross as 14.4@118mph. Stupid SRT owner. LOL.
Old 10-05-2008, 08:44 PM
JANNETTYRACING's Avatar
Next time your on the dyno turn the meth off you will see some nice gains, contrary to popular belief LOL.
Old 10-05-2008, 09:26 PM
Zach06CobaltSC's Avatar
The above will do one of two things.
Prove that you don't have a tune for methanol injection.
Or it will create so much knock that you will cry. I am guessing the 1st since your tune isn't aggressive. However, the iat2's will be much higher. If you add more timing, the methanol really comes in handy.
I hope to hell that's what he is talking about, because if I ever run out of methanol and im at full boost, it will be a sad sad day for my car.
Quick Reply: Dynoed the Harrop again today
