Dynoed the Harrop again today
Old 10-22-2008, 11:12 AM
  #176
ralliartist's Avatar
its not so much as to 1.5psi increase. It's the cfm's. You can only squeeze so much into a hole. Your head is still stock. Once you get to a certain point, the TVS just starts stacking air in the intake manifold because the head can only take in so much. At that point, the heat starts to get high.
If I were you, I'd take both pullies to the track and try them both out.
Old 10-22-2008, 11:16 AM
  #177
Rodimus_Prime's Avatar
Ah I got what you mean over summer with IATs about 20-30 degrees hotter and a leaking exhaust I ran 14.3 at 103.x that was on the 75mm
Last week with the 80mm I ran 14.1 at 103.x but thats with a much better tune, more meth, cooler temps and a working exhaust, also the best 60 foot I ever ran.
Old 10-22-2008, 11:29 AM
  #178
lsjwannabe's Avatar
you should be trapping much higher than that man, something is not right.
Old 10-22-2008, 11:30 AM
  #179
ShortStack's Avatar
and if you had a great 60'... you should probly be doing better than 14s...
Old 10-22-2008, 11:40 AM
  #180
2.23 60 foot isnt all that amazing but its better than the 2.4 I usually have, the car has never trapped high. We have been over this, its a slow car.
Old 10-22-2008, 11:45 AM
  #181
BoostedYards86's Avatar
hmm that just doesn't seem right.
Old 10-22-2008, 11:48 AM
  #182
Darkmanx's Avatar
so sell your tvs and go back to stage 2 your car will be faster.
Old 10-22-2008, 11:49 AM
  #183
SCBLKRL's Avatar
what was your 1/8th mile times and trap? Curious to see how it compares since I ran mine at the 1/8th on sunday with the 80mm.
Old 10-22-2008, 11:51 AM
  #184
lsjwannabe's Avatar
i believe 79 or 80 mph
Old 10-22-2008, 12:01 PM
  #185
my car on stage 2 was def NOT faster, its that kinda stupidity thats not helping
times are on the first page I think.
Old 10-22-2008, 12:08 PM
  #186
ur only trapping what most modded m62s trap in the 1/8. Have you started working on the timing yet. I'm just really confused.
Old 10-22-2008, 12:11 PM
  #187
invisible's Avatar
Is your clutch slipping?
Old 10-22-2008, 12:14 PM
  #188
Darkmanx's Avatar
How is it supidity? if stage 2 trap 103 any you track the same thing? if you had more power than a stage 2 then your traps would be higher if you wherre spinning but you have no explanation i unno im not trying to start a fight with you just gotta call em like i see em.
Old 10-22-2008, 12:34 PM
  #189
sadly i agree with darkmanx on this one... The TVS Redline trapped 110 with slicks on.... and he didn't have his tuned dialed in either.
Old 10-22-2008, 12:39 PM
  #190
R&C_rallySS's Avatar
^ I don't know what to think. So much goes into play. With my mods below I ran 13.5 @ 108mph on street tires. I still think tuning with meth is key for Primus.
  #191
DebadgedBALT77's Avatar
rodimus, were you at innovative's dyno day a few weeks back?
Old 10-22-2008, 12:42 PM
  #192
^ I thought Matt dynoed at like over 270 whp. That is more then a modded stage II so he should beat stage II times. I freaking ran 14.2 @ 100mph bone stock. Maybe his clutch is going or something. I would really like to ride in the car or see it. Speaking of which, what are Primus's mods? AVS + what?
Old 10-22-2008, 12:47 PM
  #193
I dynoed 282.7 with stock timing and low 11s on AFR with the 75mm the other week, I'm on the 80mm now and I just finished up most of the tune aiming for mid 11s on AFR and the timing is low 20s, also switching to bigger meth nozzle.
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 04:49 PM
no_ss
10-18-2015 11:58 PM
maliki778
10-01-2015 07:39 PM
Quick Reply: Dynoed the Harrop again today
