Dynoed the Harrop again today
#176
its not so much as to 1.5psi increase. It's the cfm's. You can only squeeze so much into a hole. Your head is still stock. Once you get to a certain point, the TVS just starts stacking air in the intake manifold because the head can only take in so much. At that point, the heat starts to get high.
If I were you, I'd take both pullies to the track and try them both out.
#177
Ah I got what you mean over summer with IATs about 20-30 degrees hotter and a leaking exhaust I ran 14.3 at 103.x that was on the 75mm
Last week with the 80mm I ran 14.1 at 103.x but thats with a much better tune, more meth, cooler temps and a working exhaust, also the best 60 foot I ever ran.
#183
what was your 1/8th mile times and trap? Curious to see how it compares since I ran mine at the 1/8th on sunday with the 80mm.
#188
How is it supidity? if stage 2 trap 103 any you track the same thing? if you had more power than a stage 2 then your traps would be higher if you wherre spinning but you have no explanation i unno im not trying to start a fight with you just gotta call em like i see em.
#192
^ I thought Matt dynoed at like over 270 whp. That is more then a modded stage II so he should beat stage II times. I freaking ran 14.2 @ 100mph bone stock. Maybe his clutch is going or something. I would really like to ride in the car or see it. Speaking of which, what are Primus's mods? AVS + what?
#193
I dynoed 282.7 with stock timing and low 11s on AFR with the 75mm the other week, I'm on the 80mm now and I just finished up most of the tune aiming for mid 11s on AFR and the timing is low 20s, also switching to bigger meth nozzle.
