E85 FAQ/sticky?
Old 09-27-2012, 03:18 PM
yellowsupercharged06's Avatar
well if were throwing millage around lol ... 06 has 50K on body and engine... and its my DD
Old 09-27-2012, 03:20 PM
carstedt's Avatar
i dont see the point in building a cobalt and not being ur DD..i mean its not like a 1400hp supra or sumtin its a cobalt lol unless its fully gutted using it for track or sumtin along those lines
Old 09-27-2012, 03:21 PM
Tjolley's Avatar
07 has 67k on the engine and body cause it's a boss and won't blow up making 450+whp
lol not bad...the stock pistons didn't like 357whp + 150 of nos very much lol..
Old 09-27-2012, 03:22 PM
carstedt's Avatar
wut nitrous kit do u use?
Old 09-27-2012, 03:26 PM
Tjolley's Avatar
i put my own kit together..I use nos 2 stage rpm/tps window switch
Old 09-27-2012, 03:28 PM
carstedt's Avatar
u have any pics of ur setup?
Old 09-27-2012, 03:42 PM
Tjolley's Avatar
not at the moment
Old 09-27-2012, 04:28 PM
Sully20's Avatar
Originally Posted by carstedt
mine spends everyday outside and in the garage at night...DD ftw!
Im with you DD Baby! Cobalt SS + DD + Shi* Load of Bolt-Ons + E85 =
Old 09-27-2012, 04:32 PM
carstedt's Avatar
hell ya!..just gotta clean it all the time so it stays nice...most ppl would never kno i drive mine in the winter...but now i got a truck for hunting and pulling the jetski so i may jus use that in the winter time so i dont have to swap my hood/trunk every winter
Old 09-27-2012, 04:38 PM
ThexGovenor's Avatar
Alright guys lets try to stay on topic here. E85 Questions, answers and general tech info!
Old 09-27-2012, 04:39 PM
  #36
carstedt's Avatar
e85 is great /thread
Old 09-27-2012, 04:41 PM
  #37
Tjolley's Avatar
ok so all i did was take my gas tune and changed the afr to 9.88..drained my tank then went from there
Old 09-27-2012, 05:01 PM
  #38
09CobaltSS1's Avatar
Quick E85 pros/cons list;
Pros: Easy power, cools combustion temps, about $1/gal less than 93.... did I mention more powa!!
Cons: Inconvenient, less fuel mileage, not readily available in most areas, requires some sort of fuel system upgrade in most cases
Old 09-27-2012, 05:07 PM
  #39
Alright added that to the OP. Upgrades for M62 is just 80# injectors unless an 05, new pump because of the week fuel pump that year. For TVS Return style fuel system or 1000cc's does that sound right? What about the LNF?
Old 09-27-2012, 05:11 PM
  #40
carstedt's Avatar
TVS does not need 1000cc's, most are on 80's
Old 09-27-2012, 05:12 PM
  #41
what about return style fuel system? dont they run out of fuel on the top end?
Old 09-27-2012, 05:14 PM
  #42
carstedt's Avatar
sum run a return style but not all..i reccommend running one personally but not every1 does
Old 09-27-2012, 05:15 PM
  #43
what about the LNF? Id like to do one edit to the OP here
Old 09-27-2012, 05:21 PM
  #44
carstedt's Avatar
LNF's dont really run full e85 from wut ik, most run e47 since they dont have the ability to upgrade the injectors like the lsj's do thats...but i really cant get into LNF platform, dont wanna giv false info
Old 09-27-2012, 05:24 PM
  #45
LNF's aren't usually recommended to run on full e85. The sweet spot for us is e47. As far as fueling upgrades, we are really limited to only 2 options. Upgraded fuel lope on zzp cams or 5th injector setup.
Stock k04 LNF's on e47 will be perfectly safe with no fuel system upgrades, only must is a fuel pressure increase on the high pressure fuel pump. Depending on the car, some LNF's can get away with running full e85 without issues with big fuel pressure drops, others can not.
A small turbo upgrade like a bnr2871, or k04+ can sometimes get away with no fuel system mods when running e47 but a minimum of an upgraded fuel lobe must be ran for straight e85.
An EFR or larger turbo running e47 MUST have a minimum of an upgraded fuel lobe and depending on turbo size and boost needs will most likely need a 5th injector setup.
Old 09-27-2012, 05:25 PM
  #46
Tjolley's Avatar
Im on 60# and a 2.8 pulley..on e85. works fine my idc goes static at 7750rpm.
  #47
Sully20's Avatar
The LNF dosent need Shi*, You can run E47 1:1 Mix easily, unless your upgrading the K04 then some people run a 5th Injector.
Old 09-27-2012, 05:27 PM
  #48
This is great guys, its coming together, Ive updated the OP with all this info. Check it out and make sure I havent put any incorrect info on there. Thanks again for the info. Im trying to credit everyone.
Old 09-27-2012, 11:56 PM
  #49
InfraRedline's Avatar
Just for the record, the 05 pumps will flow plenty of fuel for 95% of the people's setups on E85. The main problem is that their failure rate is much higher than the newer pumps. My pump finally gave up on me about a month after I put the ZZP rewire kit on my car to try to give me that little bit of extra fuel. I rev my car to 7600+ rpms on the TVS and 2.7 and I wanted a little more safety cushion for fueling before going BRFPS or RSFS. While the pump was able to slack at lower voltages and 7400 rpms max fuel demand it was fine, but when I started reving further and did the rewire (not blaming ZZP at all, the rewire clearly provided more voltage to the pump ) it just got tired and finally had enough.
Old 09-28-2012, 01:41 PM
  #50
Good info Infraredline, If you have any more that you think should be added to the OP please let me know. I know you are one of the E85 experts on here
Quick Reply: E85 FAQ/sticky?
