Easiest way to 300 crank hp.........
Old 07-28-2010, 09:19 AM
bonylad's Avatar
I am curious as to how close I would be with these mods:
zzp s2 heat exchanger
zzp custom tune for 42lb injectors, 2.9 pulley, and 93 octane
injen intake
ca v2 header
solid mounts (i know no hp, but mentioned anyway)
Old 07-28-2010, 09:21 AM
Supercharged Guy's Avatar
Honestly with that setup your not gonna even come close, sorry to bust your *****
I'd say you will probably be around 250's
TVS is the way to go if you want 300+whp
Old 07-28-2010, 09:23 AM
I'm too JDM for you
BLAZIN07SS's Avatar
spray a 50 wet shot on top of that and you will hit it. plus the car is a ton of fun on that set-up
Old 07-28-2010, 09:24 AM
Administrator
Administrator
Staged07SS's Avatar
Before I installed the H62, and 74mm pulley my car was making 291bhp (according to my interceptor). My mods were GM Stage 3, 2.99 pulley, 42# injectors, AEM Intake, GMPP Manifold, Corsa 2.5" Catback. You should be around 300bhp with the mods you listed.
On that setup I dynoed 256 whp.
He is asking about BHP not WHP.
Old 07-28-2010, 09:26 AM
zrated89's Avatar
interceptors are not accurate on reading horsepower. OP if you go down to a 2.8 pulley you should see your goal no problem.
Old 07-28-2010, 09:29 AM
Administrator
Administrator
Staged07SS's Avatar
Never said they were, but they are pretty damn close considering I dynoed 256 whp & the interceptor read 291 bhp. Comparing my dyno and bhp reading it's about a 12% driveline loss which is about what a front wheel drive car will loose.
You do not need a 2.8 pulley to reach 300 bhp.
Old 07-28-2010, 09:39 AM
My b, I didn't look
Still though on that setup he will not hit 300 CRANK hp
Old 07-28-2010, 09:41 AM
Administrator
Administrator
Staged07SS's Avatar
My b, I didn't look
He will be very close if the tune is good.
Old 07-28-2010, 09:43 AM
I agree if the tune is a very good one then yes it will be close
Old 07-28-2010, 09:56 AM
SS4ME's Avatar
He's probably running around 270 to the crank. Meth, 80s and E85 with a skilled tuner may get you close.
Old 07-28-2010, 10:07 AM
ebristol's Avatar
Why limit yourself to 300 crank hp. Go for 300whp!
Old 07-28-2010, 10:22 AM
Administrator
Administrator
Staged07SS's Avatar
He is more like 250ish whp which is more than 270bhp. GM Stage 2 equals to about 270bhp.
You do not need meth, 80s and E85 to reach 300bhp. 300whp yes, but not 300bhp.
Haha, good point sir !!
Old 07-28-2010, 10:38 AM
sput's Avatar
May want to think about a set of injectors larger than the 42lb/hr.
Old 07-28-2010, 10:42 AM
Administrator
Administrator
Staged07SS's Avatar
I really think a lot of you are not understanding the OP's original post. He is asking what it takes to get to 300 BHP not 300 WHP. It's not hard to get to 300 BHP on these cars. Most of the SS/SC's on this site are at or near that. Trying to get 300 WHP is when things get complicated, and you need mods like larger injectors, full exhaust, cooling, smaller pulley, etc.
Old 07-28-2010, 10:46 AM
selfinfliction's Avatar
nitrous
sput's Avatar
No I understood. Just saying, if he's buying new injectors, a larger set would be safer with the 2.9 pulley he mentioned as well as give him room to use a smaller pulley later when the 2.9 gets boring.
Old 07-28-2010, 10:50 AM
Administrator
Administrator
Staged07SS's Avatar
Oh ok .... I agree with you on that
Old 07-28-2010, 10:52 AM
rico's Avatar
turbo sorry I had to
Old 07-28-2010, 10:57 AM
bonylad's Avatar
Yep, I want that to start with. If I wanna change to another pulley a good friend is getting hptuners and has offered to help with that tune wise.....
I would be happy with 250 ish at the wheels.....its my dd and use it to tote my son around (2.5 months old) so I dont wanna go nutso here. I have the option of keeping a bnib 2.75 random tech exhaust or swapping for a header. I think the header will work better for me as I wanna stay low key....and like the stock exhaust sound.
Old 07-28-2010, 11:37 AM
rnjmur's Avatar
injen intake
ca v2 header
With that setup you will see 270, maybe close to 280 with a really good tune. If you want 300 Bhp you will need to go 2.8 pulley + 60# injectors + downpipe + exhaust + good tune then you *MIGHT* be able to hit 300 Bhp without meth, and with a really good tune.
Old 07-28-2010, 11:50 AM
Administrator
Administrator
Staged07SS's Avatar
You do not need all of that to reach 300 BHP.
A 2.9 on 42's with a really good tune & supporting mods will be damn near 300 BHP.
He should be at or around 250 WHP with what he has now.
You need about 250-260 WHP to be at/near 300 BHP.
Old 07-28-2010, 11:58 AM
SS4ME's Avatar
I said 270 crank which is the same as bhp. Screw bhp. Wheel hp is where it is at. If your going for 300 hp, why not go for a real 300 whp? Meth, 80s, E85 and Ebristol will get you some good numbers.
Old 07-28-2010, 12:18 PM
Stone629's Avatar
I put down 240 WHEEL HP with a 3 inch catted down pipe, stock cat-back, modded airbox, 60s, 2.8, and a good tune. If I did a header, intake, and cat-back, it ought to easily be somewhere around 260 WHP, thats all over 300 CRANK HP. It should be about 270 at the crank now.
Is E85 and Meth the only way to make 300 WHP on the M62? Nobody sales E85 around here.
Old 07-28-2010, 12:24 PM
SS4ME's Avatar
I think it's been done with 93 octane and meth, I think.
Old 07-28-2010, 12:27 PM
Administrator
Administrator
Staged07SS's Avatar
I know that.
Anyways, I agree with your last portion of your post.
Quick Reply: Easiest way to 300 crank hp.........
