Ecotec Oil Filter Relocation Kit?
Has anyone found a Relocation kit for the ecotec yet, I would be interested in this for ease of filter change, being able to use screw on filters, as well as the ability to add another oil cooler, provisions for oil temp and pressure gauges would also be nice.
Would many people be interested in this or is it just me. If so are there any Vendors on here that would be interested in tackling this, and if so could we get a group buy up and running. For any vendor that would, this would open the doors for all Ecotec equipped cars.
Can you add oil capacity and another cooler with it though, filter change would be one benefit. Doing a pulley swap according to Eaton will increase heat production. I am more interested in the cooling properties that could be achieved
i love this cartridge design, no mess at all compare to my lexus and 300zx. i hate spin on filter after i have this cobalt. my hands are completely bone dry, free of oil unlike the spin on filter. oil start leaking once the spin on filter is lose. plus, its more enviormental friendly because cartridge use less material.
http://forum.atomclub.com/index.php?topic=8619.0
Is this the kit that you are talking about?
all you need to do for the adapter plate is take the cooler off of the mounting bracket get some an fittings and thread the adapter bracket accordanly for the a n fittings run your lines and to a external oil cooler and your dun its a hell of alot cheaper then the 1200 buck bramo piece this is how im doing mine
On an Ariel Atom forum they have a picture which shows a kit from Brammo? installed.
Stock pan is pretty well designed as far as baffles are concerned, have you looked inside of one? 6 qts is plenty in a 4 cyl.
