engine build, need opinions/input
so i am looking into doing an engine build and am wondering what ur guys' opinion and experience is. here are my current mods: zzp stage 2 sc kit w/2.9 pulley and s3 he, 60lb injectors, zzp dual pass with option b, zzp long tube header/dp w/high flow cat. i currently have zzp stage 2 cams waiting to go in and am looking to do rods, pistons, valves, valve springs/retainers and neutral balance shafts. curious as to what brand/compression to run with the pistons. i am going to put a tvs w/meth injection on when i do this build. not sure if i should do a lower compression piston with higher boost or do a stock/or higher compression with moderate boost. i am aware that with a higher boost setup i will have to do a boost fuel refernce setup. well thanks in advance guys and any input will be considered and appreciated
