Engine code problems need help!!!!!
Well I wnt and go start my car the other day and went down the street and the reduced engine power came on so I limped my car back to the house to see what the problem was. For starters my car is a built hybrid cobalt ss it has a lsj bottom with a 2.2 built head on it just to get that out of the way but all in all the car runs really well except for the starting part cause of the camshaft sensor since the 2.2 head dont have i will have that code but once the car is running it seems fine.So now on to the bad part I came home got out the scan tool and here is the list of codes it threw.
p0069
p0340
p0341
p0068
p2229
p0121
p1101
p1182
Yes quite a list but I put a new supercharger inlet snesor, on and a new mass air and still wont run right it will start and run and you can rev it up slowly but if you punch it and it hits any boost at all the car shuts down and i've went all through it no leaks vacuum readings are good so im confused on what it could be and what to do.......any advise is welcome
p0069
p0340
p0341
p0068
p2229
p0121
p1101
p1182
OrangeCoba
09-25-2015 06:06 PM
