Engine Swap idea..
Engine Swap idea..
After hearing about the guy who is going RWD i was thinking of keeping the FWD but changing the engine. My idea was to swap to the L67 v6 SC engine from the pontiac grand prix gtp. I know that equal some serious transmission work but does anyone think that the engine could fit in the cobalt engine bay?
any feedback would be greatly appreciated.
from my experience that engine is still slower than most SS unless its seriously modified. Also you are adding a **** load of weight into the SS. I think it would make it slower and off set the weight distribution of the car. IMO youd be better off going tvs.
if you find and engine and trans put it in the trunk for a mid engine set up. i have been dreaming about doing this with a ford GT40 engine/trans. would make for great "what the heck?!?" moments
oh damn put a zr1 engine in the trunk of a cobalt hahaha that would be hella cool.
The added weight of the V6 will offset any HP and TQ increase you would see, plus it would be a big pain in the ass electrically and physically getting the V6 in there. You would be better off to just go TVS or turbo, probaqbly cheaper too.
It is a very heavy cast Iron motor, plus it uses a bigger trans.. the front of a cobalt is not designed to handle that much weigh..
Its doable in a Jbody but its not an easy swap.. Theres a lot of fabrication that needs to be done. Ive done ALOT of research on this swap because I may do it in my J eventually, Ive always wanted to.
as stated, the motor is heavy and would drasticly change the weight balance of the car. the tranny would fit in the car, its a 4t65e-hd, the same tranny the gm fwd race automatic is based off of. it also is heavy. the only upside of this swap is this motor can make some serious power, but you come against the same hurdles as an lsj.
a better swap would be a 3.6l dohc or a 3.9l ohv. the 3.9l is right on par power wise to the 3800s/c, the 3.6 dohc is a bit more power. the 3.6 is a wide motor and would have a hard time getting into the engine bay, however the 3.9l isnt much wider than a fully dressed (blower and exhaust manifold) lsj. this is a more realistic swap. the 3.9l is also a cast block/aluminum heads, its far lighter than a 3800 (however still heavier than an lsj), and has far better flowing heads. its only a turbo setup and meth injection away from 350whp. with a built up bottom end, some mls head gaskets and studs, a nice turbo cam, i can easily see 450hp not working it hard. this engine would mate to a 2000-2002 2.2l ohv getrag 5 speed (its the same f23 in the 2.2/2.4 cobalts, just a different bolt pattern bellhousing), it should bolt right into a cobalt.
