Engine upgrade
Engine upgrade
i want to put a stage 2 or 3 on my car. I know that there are a lot of steps that are needed part wise. Im just looking for a list of nessicary parts it would take to put the upgrade on my engine. I am farely young and just looking for some power. Please help, thank you
Try Googling for a stage 2 or stage 3 upgrade kit for your LSJ, there are a few places that have a full parts list or you can get an eyeball on what parts are included in it. CrateEngineDepot.com should have what you're looking for.
It's a great place to start! I got the GM stage 2 kit then onto stage 3 and it runs good..also come other mods but the kits are readily available and you'll get some extra power 👍..stage 3 is really fun!
Here another thing to consider..how about an exhaust? And this is a thing I've been pondering for years now..for me I have everything except a header which I'm assuming is ported..I've heard mixed things on the stock header flow to certain points etc..do us staged guys need a header? Even with a smaller pulley?
I run a ported extrude honed manifold and there are no signs of restriction from it on any of my dyno graphs.
The exhaust side is were you need to work on with the LSJ. Exhaust ported head, free flow manifold, downpipe, and catback. That's were the gains are.
Ported manifold will support 350whp. Tested back in the GM Racing days. I run a ported extrude honed manifold and there are no signs of restriction from it on any of my dyno graphs. The exhaust side is were you need to work on with the LSJ. Exhaust ported head, free flow manifold, downpipe, and catback. That's were the gains are.
Gotcha thanks Jeff! On my car I have a zzp down pipe and a vibrant exhaust all of which is very loud! By the looks of things and my experience in cars all these years it's all 3 inch..the question lies on the header which looks stock but I suppose it may be a ported one? Also u have the ported one right?
You may have a GMPP extrude honed manifold, but its not ported like mine.
Sent mine out for some extra work and increased flow.
Gotcha so really no point to consider a short header or any others like the long tubes etc for my set up anyways?
As for long tubes, no one has proven on here that they produce a substantial amount of power over any other type of header.
For your GMR S3 setup, you are prob currently in the 260whp range. A ported manifold would be more than enough for you now, and future goals.
GMPP properly ported will outflow any of the shorty headers on the market. As for long tubes, no one has proven on here that they produce a substantial amount of power over any other type of header. For your GMR S3 setup, you are prob currently in the 260whp range. A ported manifold would be more than enough for you now, and future goals.
Some swear by them. My car does not like them.
I run the NGK one step colder iridiums.
In fact my car came with iridiums from the factory.
You could also run the ZZP high output coils. That cleaned mine right up on top end. It shows out of stock but would be worth a call. If they are not going to produce another run of them I'll sell you mine. $500. Each. They helped mine that much because you can run a wide gap and pump the throttle at high RPM without it breaking up. ZZP High Voltage Coil Packs-LSJ - Ignition
Thanks for the help guys..yeah same thing on 93 octane gas on the 93 tune running like crap just bogging on shifts, hesitation, breaking up and misfiring around 35-4000 in like 3-5th..so today ran in basically dry..back to the 100 octane pump..race gas tune on..and no breaking up..pulling hard as hell and very impressive! Nice and smooth through all gears..I'm lost on this one..a little while ago I can remember running it on 93 with the base 93 tune with the run in with the corvette and it ran good that day and time period..sorry for the long post but race gas and HOM zero problems except slow drivers in my way lol
When I was running straight 91 octane with no methanol/water I think i was getting detonation and it would act like this. Didn't do it until the higher gears put enough load on the engine like yours. I also had my knock sensor unplugged though. With the knock sensor plugged in the ECU pulled enough timing to prevent it. Is your knock sensor plugged in and working correctly? Is your IC pump working correctly?
I said it before, def check your plugs and their gaps. also wouldn't hurt cleaning the throttle body, maf sensor, and injectors.
When was the last time u changed the fuel filter?
Viperoni (06-27-2016)
THIS. Crazy how people throw mods at a car without the normal maintenance activities and expect them to run their best. Not a knock on the OP by any means. But maintenance in a performance car goes a long way.
07MetallicSC (07-13-2016)
