Enthusiasts and vendors alike... header testing inside!
#326
No prob. I am going to get one more day of driving in before I post my thoughts on the vibrant setup. The dyno will more than likely happen sometime early next week. Joe is going on a well needed vacation.
#328
I've got a pretty thick gasket in place now, and the bolts were tightened down pretty good, but at low revs in second and third gear, there is a weird noise coming from under the hood. I think it's a leak as well on mine now. I don't want to break the bolts but at the same time, I don't want it to leak. It might just take some higher strength bolts and tightening the **** out of them.
#329
ye im getting that same noise at low revs under load almost like a ticking sound, and the bolts vibrant gave me were single 15mm bolts and nuts, and we i go to tighten them down the bolt would just spin from the back side... is there any kinda bolt/nut or w.e i can buy so it would not spin, almost the like stock bolt/nuts?
#332
#333
#334
#336
I don't think you have read it.... Because I clearly posted a before and after of the JBP as experienced by myself. Deathscythe also has posted his dyno and results from the JBP.
#337
From what most are saying on here, I received a severly substandard header compared to other members. I would be willing to retest with someone's vortex header to set things straight.
Fair is fair.
Fair is fair.
#338
my header is curently at my machinasts shop... ill see if he took it off and if so i might be able to send you mine...ill keep u posted, if you get another one b4 you hear back from me then cool.
#340
er no. I promise.
(thinks) I can just see stu taking on deathscythe. Like jbp, Stu = fail. more (jk)
#341
Thoughts of the vibrant header/downpipe.
Pros:
Installation is pretty much straight forward. 10 bolts tight for the header, and three to the dp.
I saw a boost pressure drop of .6 psi after swapping to this from the jbody header.
Even with a smaller than preferred collector and downpipe for my app, it doesn't seem to affect performance with the car. It pulls rather hard, and I have torque steer in first and second gear.
Picking up speed in the higher gears doesn't take long.
Cons:
First, the ******* secondary o2 sensor. Why they would put it that far back is beyond me. The cat could have been closer to the bend.
There is a ticking noise that comes from the header when picking up speed in a lower gear. It's only there for a few seconds, but it is noticeable.
And lastly, they should have made it more accessible to people with an option for a 3" going to the catback.
Pros:
Cons:
#343
[QUOTE=qwikredline;4207010]
the frickin thing dont work what more to say and JBP represent themselves as knowing what to do, and dont this is just another instance. case closed.
Dang u must be as slow to reading as on post 325 I Told him thanks and he states he needs to test a different header due to the other header was messed up even though most o there stuff has been from everyones experience. Obviously there reputation is long gone and crap. I will be doing a dyno tune with Vince after my stance coilvers come in and post numbers with a tvs and jbp header. If the header is a big issue I will gladly buy a new header from CIA. Case closed!
#344
Depending on your mods it might not be necessary though. If you don't have your mods listed on the site then list them here. That'll give us a better idea of if it will be satisfactory. But the tvs and vortex should be enough.
#346
He's a Navy sailor. His vitamins involve cream-of-some-young-guy. Just kidding! But, you know what they say: When a ship goes out it has 100 sailors. When it comes back in it has 50 couples.
#348
Pros:
Cons:
Pros:
Cons:
