Enthusiasts and vendors alike... header testing inside!
#51
#55
the jbody header is going to be next. i have to find out if there is still remnants of my cat in my downpipe, I blew most of it out the ass end on saturday.
I'll let you know. You are anxious to see what it sounds like aren't you?
#59
VB garage-
Harrop HTV1320-LSJ supercharger
Rebel 3" intake
Hahn full 3" downpipe/ catback exhaust
Centerforce df clutch
VA legal mirror tint
60# fuel injectors
icw megastar rims
halo projectors
ss/tc front grill mesh
led halo taillights
pioneer avic-d3 navigation unit
hurst sts
aeroforce interceptor x2
plx dm-5 wideband gauge
ksport coilovers
ttr solid engine mount
ttr poly tranny mounts
ttr rear sway bar
dimpled and slotted rotors/ posi quiet pads
Rebel 3" intake
60# fuel injectors
icw megastar rims
halo projectors
led halo taillights
hurst sts
ksport coilovers
ttr rear sway bar
#60
more importantly..
Mods waiting for install:
cx racing h/e
dual pass endplate w/option b surge tank
Return style fuel system
AIS methanol injection system
Vertical doors inc. vertical door hinges
suncoast hood
Engine build parts:
diamond 9.5:1 forged pistons and piston rings
rod bearings
crankshaft bearings
ported head by m2race
supertech valvesprings
ferrea valves +1mm oversize
gm racing cams
ported intake manifold by ottperformance
cx racing h/e
suncoast hood
Engine build parts:
rod bearings
crankshaft bearings
gm racing cams
#61
That's with a STOCK exhaust manifold, folks! And a conservative tune. Also that dyno sheet is SAE Corrected, which will show the LOWEST results, unlike other, including vendors who post dynos that show the "best".
This car is FAST... I've had the honor of being a passenger.
#62
everything except for the gmr cams, vertical door hinges, return style fuel system, and ported intake manifold have been installed. Like Joe said, that's with a stock exhaust manifold. So respectable numbers are possible with the stock exhaust manifold.
#65
Whoa.. is that on the stock tvs pulley? And what RPM?
I'm waiting for the chance to put my header on (thus running the manifold) and I see maybe 20.5psi at 7300.
I ported the crap out of my manifold a while back, but it wasn't 2psi worth!..lol
#66
Remember. PSI is a measure of restriction. It is not always a good thing...
#67
#68
#69
I have a 2.95" pulley installed right now. And I know 22.3 psi probably sounds like a lot, but the car doesn't feel like there is a choke point. She revs quickly and smoothly from 3k to 8k. The ported head does help a great deal, but the stock head does have something to do with the pressure being so high.
#71
I'll say right now, I'm expecting lower numbers, probably in excess of 10 horsepower. two things..., the primaries are only 1.5 inches in diameter, and there are some nasty bends in the design. Three of the four runners have at least one bend in them that will disturb airflow to the downpipe. Before I install it on Sunday, I'll take pictures so you all can see what I'm talking about.
