Enthusiasts and vendors alike... header testing inside!
Old 08-07-2009 | 04:17 PM
  #176
Deathscythe's Avatar
As of now, the meth controller is in place and working, meth is in the tank, and we are set up for tomorrow at 9 a.m. I will try to get the info up as quickly as possible, but I will be swapping to the vibrant setup before I get the chance to post up numbers. Look for info around late afternoon tomorrow.
Wish me luck.
Old 08-07-2009 | 04:35 PM
  #177
ralliartist's Avatar
hmmmmmm, I might ship you my pacesetter header/dp combo to dyno.
Old 08-08-2009 | 02:53 PM
  #178
_UnLiMiTeD_'s Avatar
bump, cant wait to see results
Old 08-08-2009 | 03:25 PM
  #179
SSLOW06's Avatar
Dam im about tot go to work then going to the club afterward !!! I will not be home till about 4am or so ! Hurry post some results !
Old 08-08-2009 | 09:05 PM
  #180
bulletpound's Avatar
BUMp for RESULTS
Old 08-08-2009 | 09:28 PM
  #181
Darkmanx's Avatar
So............,
Old 08-08-2009 | 10:49 PM
  #182
domin8_gt's Avatar
I know! I know! I've seen the dyno sheet too. I'm not going to tell, but I will say that the numbers are gonna shock some people.
Old 08-08-2009 | 11:14 PM
  #183
Here you go...
I'm gonna let this sit and fester for a little bit before I explain why it did so poorly.
Old 08-08-2009 | 11:15 PM
  #184
Zach06CobaltSC's Avatar
What was stock power again?
OH wait nvm its on there haha.
Stock was 321/254 and the JBP was 262/219, wow talk about a huge decrease! Was timing changed at all?
Last edited by Zach06CobaltSC; 08-08-2009 at 11:15 PM. Reason: Automerged Doublepost
Old 08-08-2009 | 11:16 PM
  #185
yeah, it had to because of a few different factors.
Old 08-08-2009 | 11:17 PM
  #186
What was stock timing and what was timing with jbp? Obviously changing the timing is going to affect the power, how many degrees was it dropped?
Old 08-08-2009 | 11:18 PM
  #187
Pickles's Avatar
EDIT:
Sorry bout that Death. didn't see that your dyno sheet had both mapped together. wait to here what was happening.
Old 08-08-2009 | 11:19 PM
  #188
So did the stocker make 312 or 321?
Old 08-08-2009 | 11:20 PM
  #189
Pickles's Avatar
321. 254 lbs torque
Old 08-08-2009 | 11:23 PM
  #190
Pickles - I am assuming that it was JBP's poor designing method with all of the sharp bends and the timing changes.
Old 08-08-2009 | 11:24 PM
  #191
What I posted before was sae corrected numbers. That's what I posted in the dyno thread since it's more realistic. I was just comparing the two and forgot to switch things back to sae so that is what the numbers would look like if standard. that also means that I could have picked up a few more places on that thread as well.
The timing had to be toned down since I was seeing up to 6 degrees of knock up high. The car would fall flat on it's ass up top, and I'm not about to sacrifice my engine to get a few more ponies.
Old 08-08-2009 | 11:25 PM
  #192
I hear you there 100%. How much was the timing dropped though?
Old 08-08-2009 | 11:26 PM
  #193
Pickles's Avatar
Where is your knock coming from?
Old 08-08-2009 | 11:27 PM
  #194
poor design, my mods done to the rest of the powerplant, afr errors caused by the flow of air, and the lack of useable timing caused this to happen.
  #195
It was coming from running to much timing .
Edit: ya what he said.
PSS: I still wanna know how much timing was dropped lol.
Old 08-08-2009 | 11:28 PM
  #196
Pickles's Avatar
I C. I was just making sure that it wasn't damage caused on the last run.....
Old 08-08-2009 | 11:30 PM
  #197
primary no.1 being within 1/16" of the no.3 and 4.
about six degrees across the board past 5500 rpm.
no damage done, but it's more than noticeable that the car was much slower.
Old 08-08-2009 | 11:32 PM
  #198
So if you figure 2hp per degree of timing thats 12hp, take the difference of 59hp and subtract 12 from it and you get 47hp DECREASE from running this header compared to stock lol.
Old 08-08-2009 | 11:36 PM
  #199
Pickles's Avatar
Thats an easy way to sum it up, but we can definetely see that the drawbacks of this header are more complicated than we all expected.
Old 08-08-2009 | 11:39 PM
  #200
Some of us expected it and that's why were not running the JBP lol. However I never expected THAT much of a decrease from just a header.
