Exhaust Upgrades
Old 01-15-2013, 06:00 PM
coyn11's Avatar
Exhaust Upgrades
I've been wanting to upgrade the exhaust for awhile now. Cat's clogged and now im stuck with the decision to upgrade or just patch it till i get more $$$.
heres what ive been looking at...
1) (Upgrade) ZZPerformance - Mid Length Header & Downpipe Combo #ZZ-MIDLHDP
2) Magnaflow - Magnaflow Catback System #
3) (The Patch) ZZPerformance - Catalytic Converters #ZZ-CATC
Patch and put money somewhere else (zzp stage 3)? Ideas?
06 SS/SC 2.0
Old 01-15-2013, 06:04 PM
nhanson's Avatar
Get the first one with 1.75" primaries and 2.5" downpipe CATTED.
Catback just get ZZPs 2.5" system (its magnaflow res and muffler) and its like $200 cheaper.
Old 01-15-2013, 07:39 PM
mrbelvedere's Avatar
use the search button and educate yourself so you can make your own mind up
GDS
Old 01-15-2013, 07:49 PM
574's Avatar
I'll sell you a stock dp with a cat thats not clogged
Old 01-15-2013, 08:06 PM
Honestly dont waste money on catback as its not as huge of a performance mod as it is a sound mod.
Money better spend on header and down pipe for sure. What you want out of it is up to you, shorty vs longtubes, catted vs cat.
Good luck with whatever you decide
Old 01-15-2013, 09:53 PM
coyn11's Avatar
As far as catback its more or less a sound thing, is there any sound clips/youtube vids out there of this specific catback?
what is the difference between shorty vs longtubes (other than the length).
Old 01-15-2013, 09:54 PM
Smithkid21's Avatar
^ I'm curious about this too.
Old 01-15-2013, 10:04 PM
coyn11's Avatar
wonder about the diff. between shorty and long?
Old 01-15-2013, 10:18 PM
moves your powerband around. debate over which gives you more power i dont think has been proven in concrete. I cant speak for others but i got 12 hp and 12 tq from my badmab shorty WITH a retune.
Old 01-15-2013, 10:19 PM
coyn11's Avatar
The idea of the exhaust system is to void the engine of exhaust so it doesn't hinder the engine or provide back pressure. So long tube headers seperate where all the exhaust's meet by a greater distance allowing a lower back pressure increasing performance. However long headers are harder to install and might require customization.
So the only advantage to short headers are they're easy to install and take up less room?
Old 01-15-2013, 10:24 PM
coyn11's Avatar
so with a shorty i might be able to get more power at lower RPM's but at the cost of power at the upper end?
Old 01-15-2013, 10:34 PM
bingo. thats it! with long tubes being the reversal
Old 01-15-2013, 10:36 PM
Is there anything proven in a a-b comparison lth are better than shorties on our cars?
Old 01-15-2013, 10:40 PM
coyn11's Avatar
If you get going faster sooner then wouldnt you cover more ground?
plus it seems if i go with a shorty i wouldnt have to pull an agressive 6000 RPM spirt to get the same results
Old 01-15-2013, 10:55 PM
if you have the capability to do so, make a dyno run, install long tube headers, tune and make a nother dyno run for comparison against my shorty setup. just for fun.
if not no big deal.
by getting going faster soon, wouldnt a shorty setup be better then to get you out of the initial hole? or would the long tube setup be better because after that youll be in mostly upper RPMS? or could it all be determined on the tune? each car will react differently on many factors. But an A-B before after tune to compare against mine with someone who has long tubes would be a good place to start a debate i believe!
Old 01-15-2013, 11:12 PM
coyn11's Avatar
im looking at a mid length header. ive never got ran a dyno before, id like to but how much do they run?
Old 01-15-2013, 11:14 PM
depends on the operators prices. I dont even know what the going rate is anymore since ive been on the same tune almost two years. Hoping to pick up a TVS by spring time then I could let you know. We'll see though.
Old 01-15-2013, 11:29 PM
coyn11's Avatar
Whats TVS? sorry pretty new to this upgrades thing. these headers/CAT will be my first mech. upgrade. not the way i planned but my hand was forced with the cat being clogged up and all.
Ill look around for Dyno's and im leaning toward these mid length headers so ill try and dyno before and after and maybe we could get a little insight for all of us.
Old 01-16-2013, 12:08 AM
Vander Nars's Avatar
Tvs is a bigger more efficent supercharger upgrade that bolts in place but requires a tune and supporting mods depending on the pulley size u run.
Old 01-16-2013, 12:48 AM
Zzp longtune catteds what i got. Real nice setup, the vband connection is.much batter than the shitty 3bolt stock setup. Sounds great on a stock catback just a tad louder. Power felt the most improved in the high rpms but really is still torqey as **** so idk where the real gains lie.
Oh and fitting it in really isnt hard. Slips in from the top most u might have to do is like move a coolant line ot of the way
Old 01-16-2013, 05:43 AM
if you have a lift, how easy do they slip in from the bottom? I imagine that cant be too bad either ( although I know not everyone has a lift )
Old 01-16-2013, 12:04 PM
coyn11's Avatar
Got it, yeah, i googled Tvs last night... got a bunch of flat screens. lol this makes alot more sense.
So here's the thing, im about to order the mid length header from zzp's site but i need a header gasket aswell as a cat gasket. zzp has them but i can only order one or the other. Under "Add On #1" is a dropdown box, its not like a check box. Id like to change the gaskets when i change the header and cat but do i need both? is this why i can only select one?
So should I...
1) Order it without Gaskets and purchase my own at the local autoparts store?
2) Order it with one Gasket and purchase the other at autoparts store?
3) Order it without and purchase both in autoparts?
4) Order it without and purchase them through ZZP as a separate order?
heres the link again to the package im ordering
Old 01-16-2013, 06:18 PM
nhanson's Avatar
Just pick up header gasket locally, same with down pipe gasket.
You will lose some boost with the header and downpipe but thats good!
Old 01-16-2013, 07:38 PM
Seebs's Avatar
Catback wise. Just have an exhaust shop make a 2.5 over axle pipe for you and weld a new muffler on, easy way to do a full 2.5 on these cars.
Old 01-16-2013, 09:14 PM
Gelladuga69's Avatar
This. Grab the gaskets from your local dealer. The GM gaskets are great quality and readily available.
Quick Reply: Exhaust Upgrades
