Fix?
Fix?
my ac condensor has a small pin hole leak in the middle and is leaking neon green from it..is there a way to fix this without replacing thee condensor?
Sure, but when you turn on your defroster, you're A/C is automatically turned on. A/C removes moisture which helps a lot in defrosting or defogging your windshield. You can over come this with an extreme amount of heat.
you could, we had to do that for a guy once....you would just take off the piping and remove the fluids...
you have to leave the condensor there though as a large idler pulley cause of the belt...cant remove and go smaller belt...doesnt work
You mean leave the compressor.
