fuel pump size
Rent me! per hour
fuel pump size
not dimensions, the actual flow rate.
l/hr
gph, either one will work. or does anyone know? is it a great mystery? should i consult the great pumpkin, and Ms Cleo?
l/hr
Rent me! per hour
nothing. can't find a damn thing. found the pressure rating all over the damn place, but no actual measurement on gph or L/hr.
this makes the pigmy's cry
I never said you couldn't make changes in HP Tuners, you have to make changes in the tune with every large change you make; I said while you are doing that you may as well go to a return system. Return systems are better and more easily expandable than returnless.
Rent me! per hour
the fuel rail would be easier to make, but keeping the fuel line crap that is on the stock rail/line would have to be moved, and modded, blah blah blah
FYI, I believe (If you wanted to) someone on this site said there is a stock rail that will work from the 2.2L Ecotec out of the Cavi that is return type.
