Gauging vendor interest. (COOLING MOD)
#76
you wont be able to run option b and this because they mount in the same place. i suggest you try this on the stock endplate because my buddy black06ss is running this, and the CA heat exchanger and LOVES IT. its worth a shot. let me know if you want on the list
do you have the extra heat exchanger as the 2nd or 1st one in the system?
#82
Excellent Job
MUCH MUCH MUCH more coolant. The key to this setup is to have so much volume that it takes FOREVER for it to heat up. Thus, never getting heat soaked. The old rule, more is USUALLY better Innovators like this are what make the ss/sc great and fun to own. Also, these will most certainly help us increase our credability amongst the other boosted 4 bangers. I have been working on some projects for our ss/sc's on my own as well and they should be available soon and seeing stuff like this just gives me great hope. You have done a great service here.
#83
the reason this is different than option B is because with option b, as stated before, the coolant isnt actually flowing through it so its not extra coolant in the system just extra space for expansion.
#85
damn i hate not knowing enough about the cooling system... is the bleeder your talkin about the little bolt lookin thing on the passenger side of the car on top of the h/e?? and did you just run that little line up to the new tank or what and how did you do the return line?
#89
Fail Less.
Theres like 4 possible openings on that particular resivoir. just cut the little end nubs off. one is my vent, one is feed, one is return.
However at the moment im just using it as an "option B" cuz i had a leak in the return line and need time to get another hose.
#92
nope but you can certainly buy one!
yes, thats the one. i put a pipe fitting in place of teh plug and ran the line to the resivoir. then ran another line back into a T fitting on one of the stock hoses.
4 kits are made and ready to ship. Going to walmart later to pick up boxes to ship in.
I am waiting on supplies to get the others out, but dont see them being out any later than Monday.
Denny
Spectral
JasZ71
RockstarSS
The first 4 are yours and I am PMing you now with paypal information.
Pics will be up tonight of the finished products in the boxes.
UPDATE IN THE INSTRUCTIONS. step 9 has been altered, and scissors/dikes have been added to materials needed
dead zen you are one of the 4 now, spectral needs to hold off for a week or two, pm your way
#94
stu what is the brand of the sealant you are using? i used amazing goop and i think that was a mistake because its leaking and i just resealed it with this bathtub/shower waterproof sealant and im gonna let it dry for a whole day before putting it back in.. hopefully will take car of my leak..
#95
im using"VersaChem Flowable Sealant Clear Windshield and Glass Sealer" its in a white and blue squeeze tube from O'Reillys. I sealed up these 5 tanks last night and let them dry over night, im very happy with how strong the bonds feel now.
for the buyers, you def. dont have to worry about anything rattling around haha. tight fit (good thing) and the jug is in the middle so it should be very well cushioned.
#96
http://i24.photobucket.com/albums/c3...u/IMG_3791.jpg
I think you could have used more tape.
#98
#100
the elbow connects to the hose with the T-connector in it. the length people desire on this may vary pending slight mounting variances. so i left an extra 8 inches or so for people to determine exactly how long that end needs to be. simply cut, and slide it on to the end. do this before you connect the elbow to the tank so you are not stressing the joint while you measure and what not. the elbow can not go right onto the tank because there is no connector to do such thing. make sense?
