Gauging vendor interest. (COOLING MOD)
#115
option b only uses the tank for "coolant expansion" so its not even really in the flow. this tank actually has the sysytem flow throw it. PLUS, if you go to the track you can intoduce ice cold water through the system and drain the hot stuff out.
#119
Haz l33t wheelz.
ah, i see. if used in conjunction with a CX racing H/E, and a dual pass, it would add extra coolant would it not?
#123
there is no more stress on it.
#125
ok so let me see if I understand so if we have the extra heat exchanger and using it as the second one basically going from oem h/e to cobra h/e to water pump i believe so will this just go from cobra to your res, to the pump.
