GM Racing Exhaust Ported Cylinder Head
#126
I'm going to swap the S1 cams over to the ported head, along with my supertech valve springs. I was just tossing ideas around with the stock cams.
#127
#128
I thought that the Time Attack car was sold at the Barrett Jackson auction a few years ago. I don't know who has it now or what happened from there. Hopefully it wasn't parted out and crushed.
I have seen the Time Attack Car and the 272 Concept a couple times at shows, and they are both awesome and built with quality engineering. My goal with my car was to do that same as you, build it to GM style specs like the Time Attack car, but mine would be the Redline version that GM never did. It has got a LONG ways to go on that though
#129
Nice, I'll be checking in on this.
Just had this convo a few months back. It's a shame.
#134
#135
Well, all that's left to do is remove the upper radiator hose, un screw the tensioner, and drop the chain.
Had to cut the uninstall of the stock head sort today.... had to sign off on the wifes new car
The upper radiator hose looks like it's going to be a bitch to pull off the head.
It has never been removed, and is prob glued on like all the other coolant hoses on the car, haha.
I'm pleased to see the cams and valve springs in such mint condition. The whole valvetrain looked great!
#136
#138
lol, same here.
#139
I didnt mess with it much. I tried a quick tug, and saw it didnt budge. Had other stuff I needed to do.
I'll be back at it this Wed.
Glad mine are all new/replaced.
Yeah, I didnt really mess with it. Thought it would come right off, lol.
#143
#144
nice. hey there's a how to on doing the timing set in the build book right? for my build im wanting to replace the whole set but if its too involved (which i'm sure it is) i may just replace the guide, chain and tensioner
#145
I'm replacing the guides and chain. I'm also using the arp (mrb) timing chain tensioner bolt set.
#147
Yep, the build book has everything u need to time the motor. Just make sure to follow my cam how to for timing the cam postion sensor. The build book has that part wrong.
#148
They should be fine, but it's still to good check.
My car has low miles, and the sprockets look new. I just want to get the chain and guides changed while I have her apart. Shouldnt have to touch the timing components for a while then.
Haha, thanks buddy
#150
If the sprockets look good upon inspection, than it should be fine to just replace the chain. On a higher mileage engine, it's def good to replace everything for sure.
I'm still up in the air about touching my timing chain. The plastic guide is on it's way to my house though.
I will see where I stand with funds once I get building. Just picked up a new car for the wife. I'm not cheaping out, but I have some other things that need to be taken care of being a married man now, lol.
