Good stock replacement plugs wich choose ?
These are the stock replacement plugs from NGK:
Spark Plug Part No. Stock No. Plug Gap
Standard BKR6ES 3783 0.04
V-Power BKR6E 6962 0.04
G-Power Platinum BKR6EGP 7092 0.04 This is the stock factory plug
Laser Platinum PFR6T-10G 5542 0.04
Iridium IX BKR6EIX 6418 0.04
If you are doing any mods that increase boost (any pulley change) you will want to go with at least a one range colder plug.
Most people are using the BKR7E for their colder plug and some are using the BKR7EIX. I have not seen much difference between the two in terms of people claiming better performance, however the BKR7EIX is very hard to gap as you can easily damage the electrode.
Refer to this thread for more info on spark plugs and gapping:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/1-step-colder-plugs-lets-end-confusion-22804/
