Gt2560r
Be happy that your the highest HP cobalt on the site to date
Last edited by Rangerondubz; 03-03-2008 at 03:46 PM. Reason: Automerged Doublepost
i dont plan on cracking open the motor....sleeve strength is my only limitation.
and thats around the 440ish whp mark. so my 420-425ish will be legit.
i'm here to prove that good power can be made on a stock bottom end lsj, its all in the tune!!!
thanks for the complement tho, its nice to see some people pay attention.
i shall take your line and "Ctrl C" it then i will "Ctrl V" to death so that he hopefully gets the idea thats its to god dam small.
hope you dont mind.
small ass turbo, small ass turbo,
just let me kno.
hope you dont mind.
just let me kno.
its all about the gt3076....i got that with a .6/3 A/R on my new beastly build taking place at the moment. one of the big contributions to loss of power on the lsj is the wack-ass intake manifold, thats y i got the gmp race manifold...***** pimp.
<P>
but definatly get a bigger turbo than a gt25
<P>
<P>
me having some personal 1-on-1 with my intake manifold in front of the big screen\
and yes its a wide mouth, lol
<P>
<P>
<P>
#37
#38
<P>
<P>
<P>
<P>
<P>
<P>
the LSJ rides the 30R's compressor wheel REAL hard most the VE curve, i opted for a bit larger wheel to allow for some shift across the graph that the head and intake will do.
the .63AR hotside is also a bit on the choke side of things, the upper revs its really over that point and as you open **** up (manifold, head, ect) it gets worse and worse, a T4 at a .58 is truly the minimum for those wanting power with no upper RPM range drop.
just a few quick facts from my days of specing turbos
tis a sexy manifold tho.
11mm hot side differance, thats quiet a bit of extra required inertia.
"normally" you look at an extra 75-100rpm per 1mm bump so 825-1100 rpm on paper...so i'd guess a bare min of 800~ rpm.
the hot side size will play a massive roll in this. as will the larger compressor wheel.
#39
meh, to tiny of a hot side.
#40
sure there is, i run a T4 with no issue.
spools just fine, no drop on upper end(starting to get just the smallist hint at 7300) and the rev drops per shift match its spool points dam near perfect.
quick is a relative term, you'll see spool by say 3700-3800 at the quickest, i catch full boost by 4100 so say a solid 300-400 difference........but i gain that back up top with no drop and no choke.
turbine maps are 9 times outta 10 over looked because they are a true bitch to graph out, totally different set of less well known calculations required, but your hot side is the life and death of your set up.
i had to dig up some 8yr old garrett doc to find the required calculations, not fun, but vary handy.
#42
the .63 tis a 95% good housing i'm not talking down on it one bit, nor you for that matter, just making a few statements. I do wish i had the earlier spool at times, but that 2-3 shift makes me not care.
UgliestTurtle
19
01-11-2011 03:11 PM
