GT2871r turbo or Gt3076 Turbo
Im looking at these 2 on the rebel auto worx site and i see that the 2871r is rated for lower HP but cost more than the 3076.
So does this mean that the 2871r has less turbo lag, or gives more HP but is jsut rated to stand up to less HP?
They are found here http://rebelautoworxs.com/index.php?...ec897487dbea58
Thank you very much
Thank you very much
It is highly likely the T28 is going to be a double ball bearing turbo. Which means you will get better reaction on the street. But you'll get more power out of the T3.
Put this into perspective....whos going to win the guy who's turbo spools faster and lasts longer in the powerband or the one who doesn't reach boost until he's pretty much down the track already.
Personal choice is the T28. But you could always use a small shot of no2 to get the T3 to spool quicker.
Read the description....the T28 says that it has a ball bearing as the T3 does not. I believe they forgot to say double ball bearing...because you have to have some sort of bearing in the turbo as the wheel has to spin on the shaft easily.
