Guage Face replacement???
Guys is there a write up on how to change these? How do you remove the guage bezel? If someone has pics it would be greatly appreciated.
You have to pull the lower dash off then the trim pieced. There are 2 bolts under the trim then 2 screws in the top of the bezzle. After that is removed there are 4 screws holding the ip in. There is one plug in the back. Aftere this pull the ip apart. Black cat customs has a good instructions on this nest part. First push the needles counter clockwise until they stop .mark there location on the white housing. To take the needles off spin them counter clockwise while slightly pulling up (not too hard.) After the needles are off the face comes right off. I did the led lighting but the instruction that come with are really easy to follow.
These are the ones i orded
agentirons
10-16-2015 02:11 AM
