Guys With Sportlines & Camber Kits!
I just received Sportlines and a Camber Kit compliments of BlAckOnBLaCK! Thank You bro! My question is did you guys install front and rear camber kits or just front or just rear? What's the scoop? Thank you ahead of time for your input!
Originally Posted by CTCOBALTSSS
Bueller?
Originally Posted by BlAckOnBLaCK
Seems that alot of people didn't even install the camber kits. They just slotted the OEM bolts. The other majority installed just the front kit if they even installed a kit. I bought both front and rears kits just in case, but I think you will only have to use the front ones. Japetr knows a crap load on the install of these. He wrote up a how to. I think the guide is in the suspension how-to.
Edit - yes the car was aligned after. and it was a quality allignment. four head computerized.
Originally Posted by ssnipes
Camber kits are not needed. I dropped more than an inch in front and 1.4" in the rear. the rear has no place to install a camber kit. What you bought is is front and rear control arm camber kit. these go in the front control arm. Return them for they are not needed at all.
