Hatrickstu's Icebox Mod
Old 04-17-2009, 04:21 PM
Brenticus's Avatar
Where can I find instructions for this? I've looked and not found his How-To Guide. Does anybody have the link? Sorry if this post is in the wrong place. Not sure.
Brenticus is offline
Old 04-18-2009, 02:49 PM
Brenticus's Avatar
Old 04-18-2009, 02:52 PM
hatrickstu's Avatar
i deleted it for a couple reasons.
hatrickstu is offline
Old 04-18-2009, 03:09 PM
Brenticus's Avatar
does it not work right or are you just keeping secrets now?
Old 04-18-2009, 03:12 PM
hatrickstu's Avatar
it works great. one reason is i changed the tank design
Old 04-18-2009, 03:13 PM
mexi_loco's Avatar
so would you recommend just doing your mod stu, or would you still combine it with a dual pass end plate?
mexi_loco is offline
Old 04-18-2009, 03:16 PM
Brenticus's Avatar
still wouldn't mind someone telling me what the best way to do this is.
Old 04-18-2009, 03:17 PM
mexi_loco's Avatar
buy it from stu
Old 04-18-2009, 03:25 PM
hatrickstu's Avatar
Originally Posted by mexi_loco
buy it from stu
bingo.
i like hard data. seeing as i like hard data, im not going to say "mine is way better, omg." simply because i have never had the two mods on two cars with similar setups, so i cant compare.
IMO its just as good or better as the dual pass, AND you can add ice water to the system at the track, which is a huge advantage IMO.
would i combine the two, hell yea.
Old 04-18-2009, 03:31 PM
Brenticus's Avatar
see, mostly i've just heard of it. i don't know much about this in detail. is it just a system where you exchange some cooler coolant for your hot coolant?
Old 04-18-2009, 03:36 PM
hatrickstu's Avatar
basically you are replacing the stock coolant tank (little piece of **** in front of your blower) with a 2 quart tank on the passenger fender. your stock system all in all only holds 2qts of fluid, with the new tank and 12ft. of hose you run along with it you are easily doubling the system, as well as moving it away from right in front of the blower (heat, and it makes it way easier to change your oil lol), AND with the larger inlet you can add ice to the system for the track. i usually just use extremely cold ice water. not to mention, with my kit you get an inline drain so you can just dump the hot coolant at the track and add in your cold distilled water. win.
Old 04-18-2009, 03:40 PM
stoon_cobalt_colby's Avatar
Originally Posted by hatrickstu
bingo.
how much would u want for u to build it all and ship to canada and instrustions on how to install? will this help to keep my iat2 down?
stoon_cobalt_colby is offline
Old 04-18-2009, 03:42 PM
Brenticus's Avatar
quite nice. the guys at the stealership will like the easier oil change if and when i do this.
Old 04-18-2009, 03:46 PM
hatrickstu's Avatar
its insanely easier. i change it myself though lol
i guess ill post this up...
thats it installed on my car. the stock neck and lines are completely eliminated. it works with extra H/E's as well
Old 04-18-2009, 03:50 PM
rocketrex's Avatar
hmm...can u pm me stu with a price of this badass thing...thanks
rocketrex is offline
Old 04-18-2009, 04:00 PM
hatrickstu's Avatar
proof of gains. this was on stage 2.
beginning of run, IAT2's were 102*
end of pass, (only 1000 feet), IAT2's were 113*
thats 11* increase of IAT2's from 0-98 mph. you tell me if it reduces heat soak.
Old 04-18-2009, 04:05 PM
Brenticus's Avatar
i used to change my own oil, but i just don't have the stuff to change these oil filter cartridges and reach where they are. but it's good to have proof of each oil change anyway.
Old 04-18-2009, 04:07 PM
hatrickstu's Avatar
i forget what size socket it is, but i just put it on there, hand under the blower. then slide in a short and long extension. works like a charm
Old 04-18-2009, 04:11 PM
Wolf117's Avatar
like 1 1/4
Wolf117 is offline
Old 04-18-2009, 06:23 PM
GRABBER BLUE MUSTANG GT
Corvettespirit's Avatar
Originally Posted by Wolf117
like 1 1/4
bingo...
Corvettespirit is offline
Old 04-18-2009, 06:47 PM
advise's Avatar
i believe its 1-1/4
advise is offline
Old 05-08-2009, 12:53 AM
Sachemhockey44's Avatar
i would love to do this but something tells me this is gonna void the warranty which i currently rally cant void :-/
Sachemhockey44 is offline
Old 05-08-2009, 01:44 AM
hatrickstu's Avatar
it takes 30 minutes to swap over.
Old 05-08-2009, 11:53 AM
o really?? like its easy to put all the stock stuff back if i have to bring it in for warranty?? wat kinda gains or benefits would this give me??
Old 05-08-2009, 12:09 PM
hatrickstu's Avatar
its easy as hell to switch back over after you figure out how to do it the first time. you are simply swapping some lines and what not over.
you get double the coolant capacity over the stock system, and you can add ice water at the track. ie: less heat soak on DDing, and MUCH cooler coolant at the track
Quick Reply: Hatrickstu's Icebox Mod
