Header/downpipe
Header/downpipe
I am so confused on these things.
I have a stage 2 car. With CX racing h/e. Stage 3 pulley. Injen CIA. Ingalls TD.
Other then that its stock, meaning stock catback.
I need to know what header/downpipe is best for this setup, and for ferther modding within the next year.
Also, if I need to replace the cat to get best gains. Help me out with idea's if you can.
Thanks!
__________________
Thanks!
__________________
Pretty far. I wanna go TVS sometime in 2010.
Alot more cooling mods.
Do i need an exhaust tho?
Im sorry, but I know NOTHING about header/downpipe/exhaust.
No problem.
If your in a state with emisson's or noise is a big concern get the cat as it will quite it down. If you don't mind the noise and a couple hp get catless.
If you are going to run a wideband the extra 02 sensor bung comes in handy.
If you are putting this to a stock catback it needs a 2.5" exit on it.
If you wanted to do a full 3" exhuast you would get the 3" exit.
No problem.
Okay, got it.
So I want to go with the 3' exit. I have a stock catback right now, but I will install a new catback 3' at the same time as the header/downpipe.
With the 3" I should get more power right?
Ive heard of people losing power, I dont wanna make any mistakes.
and Thank you for your help.
Okay, got it.
That is what you would want.
You will not loose power just change where you make peak power.
compucarnut
05-11-2008 04:53 PM
