Headers
nope. As far as i know it wont effect anything...i know if u are installing header/dp. When you start the car up for the first time u have to let it settle and let the wideband get use to the new air flow
Wow, a whole point that seems like a lot, although the stock setup is pretty restrictive. Depending on what your running now op, if you go with a new exhaust setup you will run a little leaner, however it doesn't appear that your tuned so don't worry about it. The gm stage 2 tunes run EXTREMELY rich so the leaner you can get them the better.
what i ment was (this is what i was told because ill be installing new header/dp/exhaust in a few weeks)...is that when the car starts up for the first time the a/f is abit jumpy so u have to let it idle abit then it will calm down.
z28addiction
09-28-2015 12:03 AM
