Help!!! cant get stock sc pulley off!!!
Old 04-25-2010 | 06:26 PM
ecot3c inside's Avatar
so I have crap lying everywhere. I have a 3 finger puller that sucks ass. and I don't know how to get this done tonight, I realize a press would be best, but no one I know has one. Is there a better puller you can rent from autozone?, I don't want to put everything back on just to take it off again tomorrow. I tried hard, even had some help, but I don't want to strip the threads on the shaft. any ideas. my **** is lying everywhere as I type this!
Old 04-25-2010 | 07:09 PM
selfinfliction's Avatar
use a hacksaw and superglue the shaft back together
Old 04-25-2010 | 07:11 PM
thanks for the sarcasm.
Old 04-25-2010 | 08:17 PM
BLUE TRANSFORMER's Avatar
zzp has a pulley removal tool. Buy it use it then rent it out to other people.
Old 04-25-2010 | 08:18 PM
slowswap's Avatar
Never use a 3 jaw puller on a supercharger. Get a pulley puller. Smoothflow pullies sells them.
Old 04-25-2010 | 08:19 PM
boost_junkie16's Avatar
BFH.. big f*cking hammer
ya, not going to wait for that! my **** is all apart now. I might just walk over to tuffy with my sc in a back pack and say "pulley swap please!", heres $30 have a nice day. Do not know if they will do it though.
Old 04-25-2010 | 08:20 PM
slowswap's Avatar
Hope you don't **** up the shaft.
You should have researched this.
Old 04-25-2010 | 08:22 PM
I did research this! everything is fine except for getting the pulley off.
Old 04-25-2010 | 08:23 PM
slowswap's Avatar
Then you would know a 3 jaw puller will not get the pulley off.
Old 04-25-2010 | 08:25 PM
I ALWAYS research my projects! what idiot doesn't, and if I had a $1 for every question I asked on here that got a response "you should of researched this", Id be balling like rossshady!
somebody on here allegedly got it off with one.
Last edited by ecot3c inside; 04-25-2010 at 08:25 PM. Reason: Automerged Doublepost
Old 04-25-2010 | 08:29 PM
ItalianJoe1's Avatar
it's possible with a 3-jaw puller, but just wait and do it with a press. Not worth damaging the blower.
LEXXONE74's Avatar
Don't listen to "Slowswap" he's just an instigator any "Pulley Puller" will do.
Old 04-25-2010 | 08:32 PM
Mr_Slobalt's Avatar
Find a local guy with a pulley puller. Do you have any friends with GTP's? I believe they used a press in the build book.
slowswap's Avatar
Apparently his 3 jaw puller did not work so you are wrong.
@ you
Old 04-25-2010 | 08:34 PM
Mr_Slobalt's Avatar
Actually, one of our guys used a 3-jaw at work to do a pulley swap I BELIEVE. He just bent the stock pulley, but he managed to remove it. No other damage was done.
Still not worth the risk IMO.
Old 04-25-2010 | 08:35 PM
thedude411's Avatar
torch it and heat it up??? i dunno if that would **** up the shaft tho
Old 04-25-2010 | 08:36 PM
i guess i will just take it to a shop to get it off.... hoofing it
No, you would cook the grease out of the snout and damage the seals way before you got the pulley hot enough.
Old 04-25-2010 | 08:37 PM
thedude411's Avatar
makes sense. lol i was wondering why noone had said it yet
Old 04-25-2010 | 08:38 PM
skatin_boarding's Avatar
Call around and find out who could do it before setting out on foot.
Old 04-25-2010 | 08:41 PM
good lookin out, way ahead of you!, calling tuffy tomorrow morning, they are literally 4 blocks away. they do trans work so they must have a press.
Old 04-26-2010 | 05:29 PM
Dis you get your pulley off yet.
Old 04-26-2010 | 05:55 PM
Yes, I went down to an independent shop (they are always willing), took about 10 minutes and $20 to swap the pulleys for me!, sweet it was cheaper than renting a pulley removal tool. Tuffy was "understaffed" so they couldn't take 10 mins, to do the pulley swap for me even though I secretly think they are just retarded. the stage 2 belt I had was super tight and I couldn't even get it over the pulley correctly even with adjusting the tensioner. I used the stock belt for it and it works pretty good. I like the louder whine and the more power!
Old 04-26-2010 | 06:06 PM
bluechevycobaltss's Avatar
what size pulley did you go with?
Quick Reply: Help!!! cant get stock sc pulley off!!!
