Help!!! cant get stock sc pulley off!!!
Old 04-26-2010 | 06:07 PM
ecot3c inside's Avatar
3" pulley.
Old 04-26-2010 | 06:09 PM
bluechevycobaltss's Avatar
and its that much louder? I have a 2.8 sitting here in my room but need to get cooling mods and injectors before I get it on, wonder how much louder that will be.
Old 04-26-2010 | 06:11 PM
mine might be louder, or it might be the seat in pants feeling especially when I put the pedal to the metal.
Old 04-26-2010 | 07:06 PM
bbbevans89's Avatar
the stage 2 belt was tight because thats for smaller pulleys than 3.0 from what i understand
Old 04-26-2010 | 07:55 PM
skatin_boarding's Avatar
haha he has a 3" pulley. Its tight but it will fit. Dont worry about it if your stock belt is fine. Save it for when you need a new belt.
Old 04-26-2010 | 08:40 PM
the919Phenom's Avatar
damn. i went thru hell to get my stock pulley off. bought the zzp stage 3.
went to auto zone to rent there pulley puller (didnt work) went and bought a pulley puller(to small) went to 4 differnt macine shops (no one could take it off) went to 2 or 3 mechanics (would not touch it) finnaly got sent to fast lane performance witch is like a 45 min drive.
walked in the place and walked out 10 mins later with the pulley off. cost me 60 bucks tho
Old 04-26-2010 | 11:23 PM
wow you got butt raped.
lol. I don't think jesus could have got that belt to fit. Unless I forgot to try another way.
Last edited by ecot3c inside; 04-26-2010 at 11:23 PM. Reason: Automerged Doublepost
Old 04-26-2010 | 11:40 PM
1badBlueberrySC's Avatar
The stage 2 kit is a 3" pulley, so the stage 2 belt will fit it... you just aren't strong enough apparently!
Old 04-27-2010 | 12:32 AM
BlackBaltSw's Avatar
Yea stage 2 belt is made for the 3.0 pulley. Its not that hard man. Seems like your missing some of the tools any LSJ owner should possess.
Old 04-27-2010 | 12:36 AM
Mr_Slobalt's Avatar
I had a hard time getting the stock belt to fit with the oversized tensioner pulley and 3.0" s/c pulley. I tried a few times, got a bit frustrated, took a smoke break, and came back to only have the belt slide on with ease. Don't you hate it when that couldn't happen the first time?
Old 04-27-2010 | 12:38 AM
  #36
Thats what happens when you do it right!
Old 04-27-2010 | 12:45 AM
  #37
Mr_Slobalt's Avatar
I worked late the night before, woke up early that day with very little sleep, worked 5.5 hard hours without breakfast or lunch, installed front brakes on my car, modified the tensioner bracket, and then finished the car by installing the belt. I was tired, hungry, and ready to go home.
Old 04-27-2010 | 12:49 AM
  #38
What did you do to the tensioner?
Old 04-27-2010 | 12:54 AM
  #39
Mr_Slobalt's Avatar
Replaced the stock 2.5" pulley with a 3.0" pulley from ZZP. I didn't have a stage 2 belt.
Old 04-27-2010 | 12:59 AM
  #40
gotcha. I was gonna replace my tensioner for when i drop to a 2.5 for the track. but i dunno...
Old 04-27-2010 | 03:22 AM
  #41
dude345's Avatar
yo man go to o'reilly's auto store they have them there.. u can rent them
Old 04-27-2010 | 10:21 AM
  #42
I hate it when stuff like that happens!, then your like 'wtf was I doing wrong before?'
which one? the bigf**ckinhammer, or the giant ass crowbar. Snap on didn't have an lsj section so I just settled with regular tools.
uhhh?
Last edited by ecot3c inside; 04-27-2010 at 10:21 AM. Reason: Automerged Doublepost
Old 04-27-2010 | 10:50 AM
  #43
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by thedude411
torch it and heat it up??? i dunno if that would **** up the shaft tho
Please do not do this ^
You should never, and I stress never, use heat to remove a pulley from a blower.
The stage 2 belt was designed to be used with the stage 2 3.067" pulley. If installed correctly it will fit his 3.0" pulley no problem.
Old 04-27-2010 | 11:10 AM
  #44
Pulley boys make a tool that takes tension of it very easily. its like 50 bucks and is a must have.
Zharrington_2010LNF
02-08-2016 01:43 PM
10-20-2015 09:56 PM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: Help!!! cant get stock sc pulley off!!!
