Help me out anyone please with ideas????
I have had a problem with my car since I installed the TVS with 79lbers. Right now I know that it isn't boosting correctly because the map is only reading 205-209 no higher. I have a 2.9 pulley on it. Ok now outside of the boost being an issue, I changed air filters the other day to an aem dryflow. Now when Im at WOT around 55-6k rpms the car freezes up. Doesn't go into limp mode or anything, keeps moving but doesnt climb until I switch gears then it still does it at that RPM. I just cleaned the maf today and no luck. Everything in HPT is normal. I don't have the log sheet, but Italianjoe1 does. IM really getting frustrated, and I really don't want to go down the road where I just start replacing parts. Oh and I have the p0172 code, which of course is rich fuel, or O2 sensor, or Maf. I really need some help. This car is starting to be a time bomb with me and I am concidering maybe even trading it in just to not have probs. Mods are.......Cobra H/e, Solid Motor mounts all the way around, TVS, 79lb Injectors, Dual Pass option B. JBP Vortex header to a zzp catless DP, 2.5" all the way to a magnaflow Exhaust. oh and my plugs right now are champion 2 stages colder gapped at .30 or .32 I don't recall. Help me out please and thank you ahead of time!
Josh
Oh and its an 04 RL
Josh
Oh and its an 04 RL
Ok I changed the TB harness and no change. I have the hpt file now and I'm still throwing codes 172 and 121. Could you guys take a look at my log file and see if anything looks out if place? Pm me your email or just post it in this thread. Thank you guys ahead of time!
Here is the log and Tune file.
http://www.******************/forums...e-ideas-2.html
r e d l i n e f o r u m s . c o m where the asterics are
