Help For The New GM Spec 2.8 pulley!
#52
Originally Posted by cavy-to-SS
kind of jerks around...wants to go fast but i gotta go slow...kinda of like its going into limp mode...
#53
Originally Posted by leviticus88
Did you change the plugs? This doesn't sound good.
#54
plugs didnt come yet...ordered same day i did pully maybe tmr or friday should be here...but i just reset the pcm and now everything is kosher...not jerks nothing at all...but plugs should be here soon...got the 1 colder plugs since everybody was saying it was fine...from CTCOBALTSSS write up (website and all)
#55
#56
umm yea you notice a big difference...well atleast i think there's a difference pulls harder and then next thing you know your already at 80 mph even my dad was like "wow" but tmr when i go to work and put gas in it i can try it out on some open road...
#57
Originally Posted by CTCOBALTSSS
That is a good question. If you didn't change the plugs you realy need to.
#58
2.7" and GM Stage kit - good idea or not?
A little off topic, but is a 2.70" pulley safe to run with GM Stage kit on a daily basis? I've been hearing different stories. Anybody running smaller than a 2.8 with their GM Stage kit out there???
#59
#60
Originally Posted by SS_SC_Cobalt
I woul dbe cautious with a 2.7 and stage kit without something like an interceptor to watch the numbers....
#61
CT add the reset the pcm to the write up if you didnt already
#62
#63
Originally Posted by p7x
how do u reset the PCM, I don't have this problem but just incase I run into it.
#64
You remove your negative cable from your battery that's in the trunk for 3 minutes and then put it back on. Done!
#65
wicked thanx man, I feel more power on the butt dyno but it does feel as it wants to go faster but its being held back. hopefully this fixes that.
I updated with an additional 2.8" discussion thread link.
#67
I took my car in and i got my stock PCM get reflashed by the dealer and for like two weeks after that if felt that same way but it it came back to life. But then again maybe i just got use to it .
#68
What if I swap in the 2.8 for the stage 2 pulley when I have my dealer install. Will the reflash automatically recognize this or do I still have to unplug the negative?
#69
#70
After the tech installs the 2.8" pulley let him do the normal reflash first and then do the PCM reset. Unplug the negative to your battery for 3 minutes and plug it back in. That should do it. The reflash is just calabrating new air/fuel and other little fixes like sporadic idle while the A/C is on and what not.
#71
6. How easy is the pulley swap?
6. Remove 4 pulley bolts, remove belt, remove pulley, put new pulley on, put the belt back on, tighten bolts on the pulley, done. Very easy!
https://www.cobaltss.net/forums//sho...t=21575&page=3
Oh and where are the original bolts on the pulley??? I don't have any. Am I blind as a bat cause I was pulling on that thing for 30 minutes. Are you talking about the supercharger casing bolts?
#72
Originally Posted by Mike06cobalt
Not saying this is wrong, but I had different experience this past weekend. Was using a 650 lb impact wrench and a puller tool to no avail. I'm going to try a press next, but can't figure how the next pulley is going to go on if it is just as hard to replace. Any ideas? Dealers are ignorant around here I guess cause they can't help me. I posted in the below thread too, but reply here too i don't care.
Be careful you dont screw the threads up in the snout of the s/c use anti seize on whatever you screw in there for lube
#74
Mike taking the pulley off the 1st time I would definitely recommend a press 20t would do it, also if you are installing stg 2, then your original pulley is replaced with a black hub and a pulley ring that is held to the hub with 4 bolts
How to I get the hub with 4 bolts on the the shaft with a press? All the directions say is remove pulley with press. OK, thats easy. Then they say install new pulley with press and makes sure not to apply force to the supercharger casing. This step is what I'm talking about. I'm guessing I have to use the threads in the SC shaft to somehow pull the shaft through the new hub, but a normal press can't help with that. What the heck do I do?
#75
Thats what Im referring to so let me reword..
How to I get the hub with 4 bolts on the the shaft with a press? All the directions say is remove pulley with press. OK, thats easy. Then they say install new pulley with press and makes not not to apply force to the supercharger casing. This step is what I'm talking about. I'm guessing I have to use the threads in the SC shaft somehow, but a normal press can't help with that.
You put it on with an installer tool, GM recommends an alternator pulley installer, but a lot have used 3rd party install tools for s/c's
