Help.. No gears in my gear box...and ideas on what it could be..
i was in first gear.. and i turned on another street, and went to put it in 2nd. and it didnt catch, nothing.. just reving.. and then after a pulled to the side of the road... i was moving the shiter around.. and still no gears at all.. i can move the shifter as if there was nothing there in a complete circle..
--Any suggestions on what it could be?
Thats like saying you put nitrous on a car but don't use it. Bullshit.
And for the record, it's either a) your shift cables or b) the roll pin.
the dealer ship i go to.. put the kit on... so there not gonna throw me out..
and if it is the cables.. ill just pay for it...its only like 40 bucks... plus labor...
and how much roll pins go for?
Last edited by Boostin_07_SS; 10-31-2007 at 10:39 PM. Reason: Automerged Doublepost
u busted ur shifter pin trust me i have done it 4 times gm is going to come out with a stronger one pm me when u find out what it was but im 99.9 percent sure its the pin and it takes about 4-6 hours to fix it and before ur pin broke did u feel a lot of play in ur gear box
And the roll pin is like a 25 cent part that they get at napa
Last edited by 2.0freakotec; 11-01-2007 at 04:27 AM. Reason: need to answer a question
no.. there was no play in it at all...
i was working(delivering pizza) and i just left the guys house... and turned on a road hit second was fine... then stopped at a stop sign.. back into 1st, and turned on the rd... and then went to engage 2nd.. and nothing there.. so i pulled over, trying to put it back into 1st and then it wouldnt go in.. and i was playin wit it.. Not One Single Gear... not even reverse...
I think its just your cables. Even if you did have CA stage 6 (i thought I read it was coming soon?) shift cables dont take any of that abuse. It would have to be a shifter install or something like that to mess them up. I may be wrong, but the only torque that shift cables get are from your hand, or when you have a gear kick you out (from a bad shift or something)
i have a pretty good idea from the guy that towed the balt this morning that it could possibly be the shift linkage... cause i was looking under the hood while my girl was playin with the shifter.. and saw a gold piece moving and i stuck my hand on it, and moved it around.. and it was loose and popped off.. and the guy said its this linkage... im just really worried that ill have to pay for it out of pocket.. instead of warranty...
You snapped your roll pin. They are shitty and can't stand up to hard shifting. Go to the harware store and pick yourself up a tension pin. they are stronger than roll pins. If you need to know how to install it PM me.
