Help putting on solid trany mounts
ok i got them i have the how to for the rear i assume the front is the same. just need to know a few questions
with a plain car jack work on holding the engine up its prolly a 3 inch circle on the how it it has the really small one
if the normal 3 ton jack works where is the safest place to put it
is there anything that i need to worry about when i take it off or putting it back on
is there any snags in the install that i might run into?
thanks for your help guys
