Hi Flow cat problem :/
Old 01-29-2010, 04:23 PM
rukkee's Avatar
Originally Posted by richienolan
yah i am goingto school up here in celeveand ohio but my housae in morgontown wv so i dont have a garge up here in ohio so i was wondering if when i got mi 42 if i could take them to who ever is going to tune it for me and i could just put them in at there place and then they could tune it for me
I would think so .... swapping injectors is like a 20 minute job and something you could do in the parking lot if you had to .
Old 01-29-2010, 06:57 PM
tru2nrtt777's Avatar
Do like they have been doing for years. go to your parts store of choice, get a 22mm spark plug anti fowler(they usually come in two packs for about $5), drill the hole bigger to fit the sensor through it(usually a 3/8 hole is plenty), remove o2, put anti fowler in, insert 02 into anti fowler.
Old 01-29-2010, 08:07 PM
Jazer's Avatar
You dont want to turn the rear o2 off, just disable the actual code that it's throwing.
Old 01-29-2010, 11:51 PM
I'm too JDM for you
BLAZIN07SS's Avatar
the 05-06 ss/sc you can completely remove the rear o2 from the system by disabling 6 codes. 07's get PISSED when you take out the rear o2
Old 01-31-2010, 11:04 AM
richienolan's Avatar
0oo000 ok well probley just di the codes dont know it the cstless dp even comes with a second holoe fore the o2 i would not think it wouild
Old 02-02-2010, 12:07 PM
ok so i might just build me an second o2 like id did for my svt that should just work just as good
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
goaliemo
09-28-2015 01:37 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: Hi Flow cat problem :/
