High flow intake manifold***picking off where rebel stopped**
Old 06-27-2009, 07:58 PM
  #76
HunterKiller89's Avatar
just a side note to you Jn2, the automatic cobalts have the engine rotated forward slightly, so the M62 swapped automatic L61/LE5 guys have a little less clearance. The biggest issue is in the pulley area. I am unable to run a pulley larger than a 3.1" on the stock blower /w stock manifold without having to cut into the frame. Just something Vulcan should take into consideration if they change the mounting geometry with the new IM
Old 06-27-2009, 08:30 PM
  #77
daythecountrydied21's Avatar
or you can get a real mans transmission...
Old 06-27-2009, 09:30 PM
  #78
freakta's Avatar
im interested to see how this works out, i know how our air to water and air to air setups work and how much they cost. would be cool to have a comparison
Old 06-27-2009, 10:03 PM
  #79
Jn2
Jn2's Avatar
the positioning of the blower will stay in the same place, cant really move it, than we risk the blower not aligning up with the the rest of the pulleys, or the intake ur currently using not bolting up, so sc position stays the same....
until he gets the manifol in he wont know how to run the cooling system, but like i had stated, will be using one like rebel intended of using, the kind that resemble a oil cooler, im going to talk to him about seeing if we can fit 2 of them in there, once right after the m62 flange, and another right before the collector
Old 06-28-2009, 02:47 PM
  #80
OneCOLDBIZL272's Avatar
Originally Posted by Jn2
tester will be heavily modded...going to need a m62 and a TVS tester, but that wont be discussed ti'll later on, ill probably test the 2.2/2.4 version of it
i wouldnt mind being your tester for vulcan, im local to vulcan ,and have a fully built motor so keep me in mind.
Old 06-28-2009, 02:53 PM
  #81
slowswap's Avatar
I'm glad to see that they'll be using a real intercooler.
Old 06-28-2009, 03:20 PM
  #82
burntorange's Avatar
^me too.
Old 06-28-2009, 03:48 PM
  #83
ei3dag3's Avatar
same here.
maybe now jn2 can beat me and not lose due to heat soak on his 3 in pulley
haha jk, i'm interested and will def be doing this mod.
vulcan has always been top notch, and i've seem all their products from jn2.
very interested in the real usage of intercoolers and not stupid laminova cores, plus the flow will make it safer for lsjs to use higher boost without having to worry about crappy flow.
im stoked.
Old 06-28-2009, 03:57 PM
  #84
Jn2
Jn2's Avatar
Originally Posted by interviewatruins
same here.
im stoked.
ahahah yeah, but ontop of that, i think my 2.25" exhaust is restricting my high end, that and the stock manifold heat soaks damn fast when i go wot
Old 06-29-2009, 12:29 AM
  #85
Jn2
Jn2's Avatar
sure will, if your local you coudl drop by the shop when done to make sure the thing bolts up to the engine with no clearance issues...i'll let them know
Old 06-29-2009, 04:54 AM
  #86
STS2/SS's Avatar
Using a real intercooler makes the biggest diffrence you don't heatsoak trust me!
Old 06-29-2009, 05:52 AM
  #87
2K5SS/SC?'s Avatar
Let's get on the stick here as I would like to see this out before I return from my deployment in October/November time frame.
Old 06-29-2009, 06:28 AM
  #88
STS2/SS's Avatar
Whooyah!
Old 06-29-2009, 06:48 AM
  #89
2K5SS/SC?'s Avatar
Originally Posted by STS2/SS
Whooyah!
That's gay. How about E O muthfucking D!
Old 06-29-2009, 07:18 AM
  #90
yeah id like to see this happen to. im almost done with where id like my motor to be and this would finish it off nicely.
Old 06-29-2009, 10:53 AM
  #91
Jn2
Jn2's Avatar
once the manifold arrives, they will go straight to work on it
should be done by than...hell by than im sure we'll have a few of them on the road
Whooyah!
Old 06-29-2009, 11:26 AM
  #92
whats the projected turn around time for the first one once they receive it?
Old 06-29-2009, 12:20 PM
  #93
Jn2
Jn2's Avatar
once they have one there, looking at 1-2 weeks before protype is made, also depend on the flange manf, bc have to order flanges, materials etc, but they quoted me 1-2 weeks
Old 06-29-2009, 12:28 PM
  #94
ebristol's Avatar
I thought this was going to be water/air cooled? What's this I hear about air/air?
Old 06-29-2009, 12:29 PM
  #95
slowswap's Avatar
No one has said anything about air/air. All we said is there going to be using a real intercooler setup!!! This should solve all the cooling problems.
EDIT: The intercooler is located inside the intake manifold and has water flowing through the inside and air over the core. The piece inside the intake manifold is called an intercooler. The piece in the front of your car is the heat exchanger. Maybe that's where you were getting confused.
Old 06-29-2009, 12:33 PM
  #96
07LaserBlueSS's Avatar
Can't wait til this is finished!
Old 06-29-2009, 12:37 PM
  #97
Jn2
Jn2's Avatar
lol this is water/air, it will have a actual core on the inside flowing water thru it, should provide better intercooling than the laminova cores with better flow
Old 06-29-2009, 12:38 PM
  #98
bowtie32's Avatar
Thanks for the updates.
Old 06-29-2009, 12:40 PM
  #99
Omnigear's Avatar
lets see how many flakes out
Old 06-29-2009, 12:47 PM
  #100
Pyros777's Avatar
^ gtfo or at least learn to form sentences.
Quick Reply: High flow intake manifold***picking off where rebel stopped**
