High flow intake manifold***picking off where rebel stopped**
#202
if you dont know what the manifold will do, if you are just guessing , thats a big leap of faith to test something; as in how to test?measured how ? compared to previous data replicated according to a predetermined protocol? Or do you just stick the whole thingn on a motor and go to an ambient condition roller dyno and find it does what? And you are paying for this? Or are the testers? I wish you all the best...
#203
Well apparently this touches a nerve. My OPINION is that it will help with cooling because of the airflow. Right now, the air must flow through these restrictive (and manifold-specific) choke points:
1) The top of the manifold, where it narrows at an extreme rate.
2) The first laminova entry port / sliver
3) The second laminova entry port / sliver
4) The third laminova entry port / sliver
5) The fourth laminova entry port / sliver
5) The fourth laminova exit port / sliver
Whereas my imaginary redesigned intake manifold would have no actual choke point other than:
1) A plate of fins and channels on a heat exchanger
That is why I am so retarded enough to think this will help in reducing temps, because of some insane notion that by not pushing the air through as many choke points will not heat up the air as much.
I know, I'm weird. I have the dual pass, extra tank, extra H/E, and I still think this will help. Call the police, I think we have an MHA....
#204
#205
Lets not let this turn into the JBP vortex header where all the owners report gains but no one has any proof.
#206
I am excited for the results!
#207
take it up with ralliartist lol, he mentioned he wanted to be a tester...im sure we could all trust him...he's unbiased...has nothing to do with vulcanturbo...he's not a vendor, a employee, or anything just another css member...also i believe arielatom wanted to be a tvs tester...
#208
we're not guessing, its just we cant go out and say "buy this it will lower your IAT2's close to ambient" you know...we are using proven intercoolers inside the manifold, using garret air>water cores, not the cheapest, but definetly one of the best
there will be a listtle restrictions on this as possible, air>water cores have a extremely high efficiency...they dont cause loads drop like the air/air cores...
#209
we are using water to air cores from garret...its a 500hp core...we ARE NOT USING AIR TO AIR CORES, that would be plain retarted...waster flows thru the inside, air flows thru the outside...who in their right mind would use a core ment to flow air both ways....
#210
its funny how you people put down sooo much that you dont know. there are a few people here who have done air to air and came up with incredible results. and there are people who have made better air to water setups. there are way better options than gm for cooling but everyone puts it down soooooooooooo bad its not worth mentioning. either way you go its been done already
#211
I have a great idea...
1. Scrap the stock air to water setup.
2. Create a tubular intake manifold straight from supercharger to intake ports.
3. Run water/meth injection.
I think this will give you the flow you need with exceptional cooling. There is only so much you can do for a supercharger that is known for heat... I.E. HEATON
Here I did this in about 10 min... obviously just to give you an idea...
Actually I'm not sure you would run water/meth that close... but you could dump it pre-supercharger...
#214
#216
#218
Thats the first thing every company wants in a new design/invention... something crazy... that hasnt been done before, thats where the good ideas come from... even though 4 nozzles is nothing new.. its different for a cobalt...
Yes that was the "idea" I was just bored at work fartin around...
Here.... maybe some sort of water to air and instead of running laminovas, run a heat exchanger sort of deal/ along with water/meth....
#220
#221
the manifold will have meth/n2o ports as a extra option..they're looking into using Garrett water/air cores(basically a h/e) in the manifold...also...also a little of topic update...Vulcans new m3 intake mani outflowed the high flow manifold from BMW...
#223
We hired an ice truck for the test. It used so much ice.
end of experiment. It is a great story and its true. It will work for 1/4 mile for sure...
There are some nice drawings here, good ideas and great energy from Jn2 but there is no engineering analysis here its trial by error, and someone is gonna pay for it and the cooling enginering analysis if you care to do it, says this wont work. So what did youget for your money?
But go ahead. I dont want to squash ideas but a little scientific method would be good to justify spending all that time and money.
#224
Interesting to see what comes out of this.
I run with the standard LSJ manifold, but for my mid-engined/RWD car with GM Ecotec engine I had some thoughts sketched for a new manifold with proper straight runners, a plenum and a plate type (water) cooler core inside. The SC had to be turned upsidedown and lowered for this (lower mass point, 850kg car!) and the alternator is repositioned in the AC spot. (No AC in my car, I have the Atom SC belt layout. And no roof. )
This would be so much work for no proven gain and probably a lot of issues with placement (the oil filter, the starter), so it will probably never be realized:
Note: This will probably never fit into a US Cobalt/Redline.
