High octane fuel?
#51
I think more people should operate their vehicles (at least 100 yards away from me) with wreckless abandon. In fact, I'm pretty sure we should encourage spray as the first modification that anyone makes when the purchase a car... and highly encourage it amongst high school drivers... and I highly support self installation, even if you don't have the skills to even change your own oil (which I have never done on a car actually)...
#53
Rent me! per hour
i see what you did there sir, and i must say, it's funny!!!!
#54
Did you see that i said that i did change the timing and installed colder spark plugs,... anyone? i dont exactly call that tuning. my a/f ratio didint change at all. after installing the nitrous. i dont get all the disrespect on this site. if there is anthing else that should be changed just say so. that was the question. not
"lol ohhhh nothing, because apparently you don't have to tune it.
gee, why didn't i know this on my past 6 cars that i have sprayed.
::slams head into desk::
#55
#56
#57
Rent me! per hour
hmmmm
okies
im here just to give people the facts of it. you have to keep more then 2 jets in the car at all times.
a/f ratio changes with bottle pressure. say you think it's fine at 950 psi. what happens when it's at 1100 psi?
it's leaner. jump up a jet size.
what happens when the pressure is 850? richer, jump down a jet size. .002 either way will keep the a/f in check, in a safe zone.
im in no way talking down on what you are doing, i just hate seeing people getting the wrong info, or just part of it
#58
in short, you just put jets in, backed timing down.
hmmmm
okies
hmmmm
okies
#59
#60
I hope you weren't disrespected by my response. But anyway as stated playing with timing is tuning. Also like stated (I don't know what plugs you have) I stay away from platinum with nitrous. As bottle pressures change you get less nitrous injected. I'm not sure on this since I've been out of the nitrous game for like 4 years, but I think zex has a kit that monitors bottle pressure and adjust fuel pressure accordingly so there is less tuning. Hopefully someone who's still in the game can chime in on that one.
#61
Rent me! per hour
they have jets like every other kit on the market.
pull a box apart, the solinoids are still the same as everything else.
just stating a fact, nothing more.
#62
How do they get away with their advertising? Here's a quote from their site:
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
I know they have solenoids, and jets obviously. Otherwise how would you choose what shot you want/or activate the flow. But for them to advertise what it does, there has to be something else inside that little purple box to do something remotely close to what they are saying I wish I had one to rip apart and see what's going on inside.
#63
Personally, I would take it to a performance shop that deals with nitrous on a regular basis. If you look around on here, there are very few people on here that are spraying and those that are, many of them had their setup installed for them. For me, I would want a factory certified installer to do the work for something as volatile as nitrous on my vehicle. They have them everywhere, hell, we have a few here in Alaska, so I'm sure there is somewhere nearby you that could do it as well. It might cost a bit, but in the long run it is definitely worth it. As for the spark plugs, I would have gone with Zex plugs with nitrous, they perform better in a nitrous environment than do any other plugs on the market. I used them with my sprayed Celica, and had absolutely no issues with it, and I use to run spray all the damn time like an idiot. I'd be driving to the grocery store spraying sometimes... and never had an issue with Zex. But I had that kit and everything to do with it tuned professionally... and didn't mess with anything, except bottle changes.
#64
#65
With my Zex kit on my Celica, I never had to monitor ****, it was all done for me. I had to watch my bottle, and watch for things that look out of the ordinary, but other than that, I really didn't have much to worry about at all. I never changed out jets, I just let the system control it and I never had any issues, regardless of how full the bottle was. The performance seemed to be the same whether I had a full bottle or nearly empty one.
Last edited by widebody_balt_ss; 05-28-2007 at 08:26 PM. Reason: Automerged Doublepost
#66
Rent me! per hour
on their dry kits, there is NO way to monitor fuel pressure. i have installed at least 40 zex dry kits. there is a bottle feed, integrated tps switch in a lil cpu board.
the wet kits are easier to explain. they have what is commonly refered to a hobbs switch. it shuts off below a certain psi. which shuts down the system. simple. it is just in another form.
all of this can be done with other kits, and a few add ons.
there are ways to monitor everything, such as an FJO controller, or the stupidly expensive venom nitrous kit.
i prefer the kiss method.
K keep
I it
S simple
S stupid
take it how you will. i have never used saftey crap, i have never used a zex kit on any of my own cars. i have never lost a motor to nitrous.
ok now i go!
K keep
I it
S simple
S stupid
ok now i go!
#67
K keep
I it
S simple
S stupid
ok now i go!
K keep
I it
S simple
S stupid
ok now i go!
ok, now I go!
#68
I swear it's like I keep reading the same thing over and over... but with different people saying it. ;0
#69
#70
I ran a ZEX dry kit on 3 cars now. On 2 of them, never did any tuning to it other than basic mods and changing our the sprak plugs.....never had a problem and the cars ran the same as they did before installing the kit........now I don't know anything about putting them on an SS/SC.....but just stating another fact that if you do your research and know what you are doing when you install it and use it, you won't have a problem. People who blow up their cars on nitrous are just idiots.
you're crazy
you're crazy
#71
you're crazy
you're crazy
#72
I also wouldn't ever use a dry kit on a forced induction car. The FI cars already have a huge strain on the injectors, if you use a dry kit you'll be putting even more fuel pressure through them. I do however like them on n/a cars under 150 shot. They are perfectly fine and simpler to install (not that a wet kit is much more involved). But what I'm not understanding is how a hobbs switch is compensating for bottle pressure. Hobbs switches are either open or closed circuit. So what it sounds like you are saying that is when the bottle pressure gets below a certain psi (or over if more then one switch is used) it will do what? Shut the nitrous solenoid? BTW, I used safety devices on nitrous setups. At least a FPSS/window switch (hobbs) is something to use and it's cheap protection. Spraying at too low or an rpm can be catastrophic as well as your fuel pressure dropping for any reason.
#73
^^ good info...
lol. im looking to the name of the thred and then reading back about 3 pages.... you would have no idea that this started as a fuel thred huh?
#75
