How to adjust B&M Shifter
Old 03-16-2006 | 09:22 PM
tube's Avatar
To adjust your shifter so that it doesn't sit so far forward in 1st gear, all you need to do is:
1. Shift into 4th gear, make sure you're in 4th gear, or things could get bad.
2. Loosen the clips on the passenger's side cable clip.
3. Slide the passenger's side cable clip completely forward, toward the front of the car, until it stops.
4. Re-clip the cable clip
You won't alter anything by doing this because the cables still correspond correctly, as long as you only move the right cable clip, it wont screw anything up.
It moves the shifter about an inch backwards, so that it's more centered.
First Gear
Neutral
Second Gear
Old 03-16-2006 | 09:25 PM
JCswoosher2's Avatar
yeah im having problems putting my Shifter in reverse. Its rubbing on the stock cuplet. Thanks for trying to help others
Old 04-14-2007 | 03:21 AM
DragRacerX's Avatar
I am having the same trouble going into Reverse. Did you find a solution? DragRacerX
007Buff
06-11-2017 03:04 PM
biniecki
10-25-2015 02:23 PM
justinchinn
10-02-2015 12:18 PM
Cptnslo
09-24-2015 09:32 AM
The Rookie24
09-20-2015 04:33 PM
Quick Reply: How to adjust B&M Shifter
