How to check if your Intercooler Pump is working ok
I turned on the car and let it run for a couple minutes and then I slowly removed the cap on the intercooler filler neck. If you see it swirling wor bubbling then it's working. If not..... It might be dead. If that happens tap the pump with a hammer it might get it going again.
Are you serious? I just saw in the filler neck, there is water swirling around but its white. Idk, I think I need to flush the entire system because I can't find here Dex-Cool and my reservoir tank is running out too quickly. I need to put Prestone Extended Life Coolant but I'm must sure of the process the flush everything out.
100+ on ottp or zzp
100+ on ottp or zzp
Yep.
Also for you guys freaking out.. Use Prestone Dex-Cool 50/50 pre-mixed. It can be added directly the system without the need for flushing and all of that ****.
Dex-Cool is Dex-cool is Dex-Cool is Dex-Cool is Dex-Cool.
Just don't buy the "mixes with any color". None of that cheap green ****.
